Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-12-2008, 11:51 AM
92teggsr 92teggsr is offline
97 Prelude randomly turns off on the freeway! HELP!!!
I got a 97 Prelude and it just started randomly dying when i drive on the freeway. It doesn't do it a lot (maybe once or twice in 20 miles on the freeway). I can start it right back up after it dies and it runs perfect otherwise. Doesn't hesitate, has lots of power.... Does anyone have an idea of what it could be???
THANKS!!!
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 03-12-2008, 12:48 PM
frisnosity frisnosity is offline
Re: 97 Prelude randomly turns off on the freeway! HELP!!!
hey, i had the same problem, turns out there was a recall for the ignition. My car turned off all the time. At one point i was the only one that could start the car. Where the key goes in can go bad. I would look into it!!!!! It was frustating. Hope i was able to help.
Old 03-12-2008, 12:50 PM
Oh yeah when i brought the car to the dealer i didn;t have to pay for the work cause it was hondas fault. call a local dealer and see what they say. This happened to me about 4 years ago. Let me know how it works out, also i had some module go under the steering column go i cant remember what its called.
Old 03-12-2008, 01:09 PM
thanks for the help! i'll try that.
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 08-07-2008, 02:04 PM
dezmahomedanizes dezmahomedanizes is offline
i fixed this problem many times. its the ignition coil. its on the other side of the ignition where the wires come from. you take that piece off and replace it. it wont stop randomly again. this is a problem also on accords. also if your vehicle starts and dies right away, replace the main realay. these relays cause same symptoms, however the car wont shut off while driving.
Old 02-03-2009, 11:02 AM
brentrevok brentrevok is offline
There's a recall due to that exact problem. It's service bulletin #02-031.
Electrical contacts in the
ignition switch can wear prematurely due to high electrical current passing through the switch. Worn out ignition contacts could cause the engine to stall without warning. Although the engine will restart in most cases, a vehicle that stalls while driving increases the risk of a crash.
Dealer should replace free of charge.
Old 02-06-2009, 10:26 PM
mavrick951 mavrick951 is offline
Yeah lol my buddie had that problem ALLDATA ftw i love there bullitens and what not but yea free off charge for recalls its allways good to check the recall bullitens at least once a year.
