Old 01-31-2011, 09:31 AM
scarecrow0529 scarecrow0529 is offline
bad ground?
when i turn the key to get it started it just goes dead lights and all. it started when i pushed the clutch down to start it it just ckicked and buzzed then dead. eventually i did get it started and just to check i turned on everything and it bogged down alot but didnt die. it s an 89 with standard 1.5 engine.
Old 01-31-2011, 02:49 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: bad ground?
I got nothing out of that.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-29-2011, 03:14 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Re: bad ground?
Sounds like gibberish...
Possibly your ignition switch? Mine clicked and buzzed like that awhile ago, new ignition switch solved the problem.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 03-29-2011, 05:46 PM
inafogg inafogg is offline
Re: bad ground?
have you checked the charging system?how did you finally get it started jumping
with another car or pushing & poping clutch?? ck battery cables,charging system,
& battery
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 09-01-2011, 05:07 PM
Re: bad ground?
i changed my negative battery cable and that fixed it.
Old 09-08-2011, 05:08 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: bad ground?
Did it take you 8 months to fix that?
97 nissan p/u, bad ground? cplstew General Discussion 1 10-10-2004 08:24 PM
Bad Ground? 1viadrft 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 38 09-09-2004 07:35 PM
Found-- Bad Ground Wire Lotus49 Camaro Discussions 12 08-14-2004 03:58 PM
93' Olds 88 bad ground? khbartlett Eighty Eight 6 04-21-2004 08:21 AM
Electrical issues, bad ground? loose connection? Motro Mofo Engineering/ Technical 2 08-22-2003 12:17 PM
