Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 08-25-2004, 05:48 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Exclamation Bad Ground?
Hey FellaZ...
Not sure WTF is going on with my Zed. Still having alarm problems and now I'm stalling. Alarm is on the fritz and beeps all crazy for no apparent reason after I arm it. My BATTERY light went on this morning and she hesitated starting but ran fine afterward (low power... sputtering... wanted to shut off... but ran fine afterward!). I can start her right up sometimes and then shut her off a few minutes later and try to start her up again... then... I HAVE NO POWER WHATSOEVER... it's like my battery is unplugged.... lights will not turn on, engine won't crank-over, SECURITY light stops blinking (that is always on BTW)... ABSOLUTELY NO POWER! I try arming and disarming my alarm when this happens and all I get is a weird BUZZZZZZZZZ from the dash (???). It seems if I open the door and try to start her up it works (???). I had the idiots at AUTOZONE check my battery again and it's fine... could they be wrong? Also a blank amber 'check' light comes on the left of the dash opposite of the CHECK lights to the right. What is that? Could there be a bad grounding? Something else? What????? Sometimes when I'm at idle it wants to stall also (ala: need a new ALT.... but I just replaced it about six months ago). I have no radio in the car... no other power draining electronics (aside from my BLITZ POWER METER). I know it has to be something electronic. Please help! I hate driving my Z without knowing if she is gonna leave me stranded! I'm driving her now and she is running fine... but this happens almost daily now!
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 08-25-2004, 07:36 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
i dont know what to tell you man. that blank amber light across from the check engine light is your transmission light. could mean anything from a bad signal or whatever. i dont know if it is a bad ground but i just replaced my terminal hooks and the wire of the ground that leads to that little hook on the back of the engine bay wall and my car ran a lot smoother and it idled smoother. it could be a short draining your battery causing stress on your alt.
ZedEx Crew Member #4
Old 08-25-2004, 08:23 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: Bad Ground?
if something isn't grounded, invest into this http://www.performancenissanparts.co...5285300a1a76e7 i would get one but need money for other stuff, i have heard so many good things about grounding kits.
ZedEx Crew Member #2
Old 08-26-2004, 12:11 AM
1viadrft's Avatar
Re: Bad Ground?
Shit... I'm PISSSSSSED!
Yuh... I have been eyeing the HKS grounding kit....
Old 08-26-2004, 01:45 AM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: Bad Ground?
Check the connections to your battery terminals.
I was driving down the road one night in Florida and my (other) 300 just died. Completely. No lights...no NOTHING...I was like...whaaaaaaaaat the fuck? All it was was the battery cable came loose from the terminal. Try that.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 08-26-2004, 10:50 AM
1viadrft's Avatar
Re: Bad Ground?
I checked it already... but I guess I should double check everything by now...
Old 08-26-2004, 04:11 PM
Re: Bad Ground?
It's worth a try...just to make sure, if nothing else. It would suck ass if you went through all kinds of trouble trying to find a problem and it turned out to be that the whole time...all you had to do the whole time was tighten a nut...
Old 08-27-2004, 12:21 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Fortunately with electrics its often something simple. For example, the running lights on my 240sx wouldn't come on, yet the brake lights and turn signals would work by themselves. Popped the fuse panel and pushed in the one that stuck out a little, Good to go.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 08-27-2004, 02:32 AM
la300zxtt la300zxtt is offline
Re: Bad Ground?
Could be the cables them selfs actually had much worse problems car would shut off under serious G's like on canyon runs. I replaced the whole negative and postive battery cable assembly as my cables were very correded and melted housing. Granted its about 156 in parts and a lot of laber because you have to unbolt half of the tranny I belive and it goes all the way down to the back bottom of the block.... But also do this take a curcit tester remove the negative battery cable and connect the circut test from the negative batter cable to the negative terminal the light should be off or very very dim. If it is not you know based on how bright the light gets you have a serious short.
Old 08-27-2004, 02:53 PM
1viadrft's Avatar
Re: Bad Ground?
Thanks for the tip... will do!
Old 08-31-2004, 01:29 PM
1viadrft's Avatar
Re: Bad Ground?
I spoke to someone who had the same problem as I... told me it was his battery. Even though the battery was checking OK it was bad. So I opted for a new battery... an OPTIMA battery! I bought myself a red-top and it has done wonders! My Z fires right up and no more dimming!!! YaY! Alarm is still retarded though... thinking of replacing!
Old 08-31-2004, 08:43 PM
Re: Bad Ground?
I've heard so many killer things about Optima batteries...going to get a deep cycle yellow top when I get a system in my car.
Old 08-31-2004, 08:54 PM
Re: Bad Ground?
i would love to get an optima. but i don't have $150. glad to hear your car is fixed 1via.
Old 08-31-2004, 09:54 PM
1viadrft's Avatar
Re: Bad Ground?
Yeah... now I just gotta get tires....
Old 08-31-2004, 10:00 PM
Re: Bad Ground?
sounds like me. i was always getting other stuff for a little while when i really needed tires. i say get new tires as soon as you can, it makes a huge difference.
