Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 04-17-2004, 08:59 PM
khbartlett khbartlett is offline
93' Olds 88 bad ground?
This 88 has a 3800, just started intermittantly running rough, and now I backed it partway down my driveway and when I went to put it back in the garage, everything looked normal until I turned the key to start it. The interior lights got dim and the ignition is just clicking as if the battery was dead. It's not, I hooked up some jumper cables to my truck, but the lights are still dim and flickering. Could I have a bad ground?
Any help would really be appreciated.
Old 04-19-2004, 04:51 AM
michelq michelq is offline
Re: 93' Olds 88 bad ground?
pull your batt cables and clean them
Old 04-19-2004, 06:31 AM
Tried it, no help. I get a solid 12.5 volts measured between the pos. battery post and the block.
Old 04-19-2004, 07:21 PM
auto trainy auto trainy is offline
check the battery cable ends (pull on them )they sometimes currode from the inside
Old 04-19-2004, 11:57 PM
Creative Creative is offline
Also check down by the starter some times the bolt get's a little loose and lose the + side .... And it might also be the contactor in the solonoid or the copper bolt .. some times they get pitted and burned .....
Old 04-20-2004, 05:35 PM
Thumbs up
Thanks for the replies, It was the Positive battery cables, it has two cables, connector plates and a long side terminal bolt. The plates were severely corroded, I cleaned them (no really this time) and now it runs like a champ again. Michelq - you were right!
Old 04-21-2004, 08:21 AM
thank you for posting the fix
