Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-17-2011, 08:13 PM
adamgrant adamgrant is offline
99 Jimmy "clicking" behind glove box
Hey, I just bought a 1999 jimmy 4x4 4 button, I could hear a clicking from behind the glove and found a relay ti be constantly be clicking but seems to go away when the brake pedal is pushed. Also had P0740, trieed to clear but must be a hard fault, comes back after a coulpe key cycles? Plus I noticed coolant on the top left if the engine leaking... are they know for intake gaskets?
Old 01-17-2011, 08:31 PM
old_master's Avatar
Advisor/Moderator
Re: 99 Jimmy "clicking" behind glove box
The clicking might be the turn flasher caused by dirty contacts in the multifunction switch. There is a thread in the Blazer "How-To" section that explains how to clean them. The multifunction switch is expensive to replace so cleaning it is worth a try.
The P0740 indicates a problem in the Torque Converter Clutch, (TCC) circuit. Could be wiring or the solenoid inside the transmission.
The 4.3L is very well known for lower intake manifold gaskets to leak coolant...and oil...and vacuum. Felpro makes a redesigned gasket (MS98002T) that will permanently fix the leak(s). There are several threads in the Blazer "How-To" section that will "walk" you through the repair.
You have to know how it works,
to figure out why it doesn't.
Old 01-19-2011, 09:29 PM
So yeah that was the right idea.... I just finished the lower intake gaskets and now is a no go? P0336 is set, I took the fuel pump relay out and cranked her over to flush out the coolant.... now seems like theres no fire.... should also mention I replaced the plugs, wire, cap and rotor??? Pretty sure the distributor when back in the same way it came out also.
Old 01-20-2011, 01:39 PM
old_master's Avatar
Advisor/Moderator
P0336 is a problem with the crankshaft position sensor, that's why you're not getting spark. Follow the wiring from the sensor and make sure everything is plugged in correctly.
Old 01-20-2011, 06:15 PM
So it turns out the rotor button had an open in it!!! My fault, should have paid for OEM... Thanks for the help.
Old 01-20-2011, 06:25 PM
old_master's Avatar
Advisor/Moderator
An "open"??? Please explain.
Old 01-20-2011, 07:17 PM
no continuity...
Old 01-20-2011, 07:49 PM
old_master's Avatar
Advisor/Moderator
The ignition coil has ample voltage to jump a half inch gap. Even if the rivit that holds the rotor tip on was loose, it wouldn't cause a no start condition, and it certainly wouldn't cause the P0336 to set. The P0336 is set when the ECM doesn't receive a signal from the crankshaft position sensor. The CKP sensor data is what the ECM uses to fire the ignition coil. Did you check all of the connections for the CKP sensor? Is the Service Engine Soon light on?
Old 01-23-2011, 02:42 PM
I'm not sure why it was that way... the only thing I did was swap rotors... the MIL is on but only with P0740
Old 01-23-2011, 06:23 PM
old_master's Avatar
Advisor/Moderator
That's odd.... If the P0336 is set in the future, check the circuits for the CKP, it's only thing that will set that DTC.
Low Heat/Gurgling Noise Behind Glove Box brian97ls Problem Diagnosis 19 02-21-2011 01:56 PM
Fan Connection behind Glove box userpete1037 C/K 3 08-03-2009 10:47 PM
98 Jimmy heater problem, noise behind glove box pitbullvassar Problem Diagnosis 3 06-03-2009 09:59 PM
noise from behind glove box 70165 Caravan | Voyager 1 07-31-2008 12:25 PM
Object behind glove box kodak06 Regal 4 05-20-2005 07:50 PM
