Old 08-03-2009, 02:42 PM
userpete1037 userpete1037 is offline
Fan Connection behind Glove box
Behind the glovebox in my 95 Chevy 1500 truck is a connection that controls the fan. I had to go to a junk yard and replace it because mine burned out. I notice when I cut my fan on High and the level down from high, that connector gets extremely hot to the touch. My questions is, What is making the connector so hot? I'm afraid the other may burn out as well.
Old 08-03-2009, 02:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Fan Connection behind Glove box
It may actually be the resistor pack that the connector plugs into that is overheating. Check and replace. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-03-2009, 09:01 PM
j cAT j cAT is offline
MAKE SURE the connector is clean ,,no corrosion...and fits tightly..
if it does get too hot the connector may loose it's clamping force..
this then if good would be as mentioned the heat from the droping resistors to lower the motor speed...
also check that the air box is clean and no restrictions to the air flow...debris of leaves,,,dead rodents...etc...
Old 08-03-2009, 10:47 PM
Thanks for the responses. I will let you know how it goes.
