Go Back   Automotive Forums Car Chat > Ford > Contour
Old 01-01-2011, 04:48 PM
iwishuheaven iwishuheaven is offline
Where is the water pump?
I have a 1999 Ford Contour SE with a 4 cylinder engine. Does anyone know where the water pump is located? I have a coolant leak on the left side of the engine. I've heard the water pump is on the right underneath the batery, but I've also heard some say it's on the left side, which would coincide with my leak. I may try to replace it myself if it's pretty easy.
Old 01-02-2011, 06:18 AM
stv840 stv840 is offline
Re: Where is the water pump?
The water pump is on the front of the engine the pully in the middle.
It's not to easy though you have to remove the motor mount and support the engine. If you do do it leave the belt on and remove the pully bolts first then remove the belt and then the pully then remove water pump bolts. you should torque all bolts as well.
Old 01-02-2011, 07:54 AM
Toolman56 Toolman56 is offline
Smile Re: Where is the water pump?
Hi, you did not say if its like for example a 4.9 , 4 cyl or a 2.2 4 cyl, for example, most these were sideways engine and not in front , like he said, most these engines run the the water pump off the timming belt assembly and too replace the timming belt at the same time , this not a do it selfer project, unless you have lots time on your hand, check other areas for leaks ,like ends of raditor hoses,small hose, clamp's ect, also never check engine with the engine or in hot cond, if there is a antifreeze leak and steam is escaping , get away from the steam , this steam is lethal and will kill you, always check for leaks with a cold engine, Everett.
Old 02-11-2011, 08:10 PM
jeremy06 jeremy06 is offline
Send a message via Yahoo to jeremy06
The ford contour only comes with 2 different style engines the 2.0 4 cyl, and the 2.5 6 cyl, Also I have heard the 3.0 6 cyl also fits.....
Old 02-19-2011, 12:00 AM
The waterpump bolts in behind the timing belt. My short describ.. Remove neg battery cable. Jack pass front, remove tire and inner fender plastic. Next remove drive belt and now place jack under oil pan and raise slighty. remove pass side engine mount. remove crankshaft pulley and and bolts holding timing covers on ( I think these were 8mm) remvove valve cover to place the piece of steel bar to hold the cams in place while you lossenen the timing tensioner and remove belt(timing belt) Between your lower idler pulley and the tentioner is the waterpump. Must remove waterpump pulley to reach all waterpump bolts.
where is water pump? davemoore29730 Escort 3 07-03-2006 01:09 PM
Where is the Water Pump - 1995 Quad 2.3L eappiah Achieva 3 05-24-2005 07:33 AM
I can't get the water pump pulley/casing to seperate from the water pump. mikev08826 Grand AM 4 03-06-2005 03:00 AM
Where Exactly Is The Water Pump Located FRANCO301 Aurora 7 03-24-2004 04:25 AM
1991 Acura Integra ???Where is the water pump located ;-) kde Integra 2 08-15-2003 10:00 PM
