Old 12-22-2010, 03:37 PM
SRC1968 SRC1968 is offline
Angry 2002 T&C limited Engine knock
I hope someone can tell me how to fix.. or at least tell me how to know if it can be fixed...
about 1 wk ago, while driving my wife heard this knocking. it don't matter if its idol or accelerating, it knocks.. and it is gettign louder. someone told me of a knock sensor... can that cause it? or is my engine kaput
it has 120K miles.. and i just bought it 5 fricken months ago.... is there anything i can do to fix?? when i checked the oil it was bone dry... added 4 qtrs right away.... did i not catch this intime??
Old 12-22-2010, 04:30 PM
mopar96 mopar96 is offline
Re: 2002 T&C limited Engine knock
was that the fisrt oil change u did??? Im sure a knock sensor will cause that and really its a cheap fix even if it dont fix it.. what really needs to be checked is WHY there was NO oil??
Old 12-22-2010, 11:50 PM
stv840 stv840 is offline
The Knock sensor only senses when the engine is knocking it dosn't cause a knock and for the most part wouldn't stop a knock
If it was 4 qts low on oil thats more than half the oil that leaked out so you have to look for leaks
If it is still Knocking determining whether it is a rod knock (major problems) or a valve tappet (a problem maybe you could live with) is the next step
Old 12-23-2010, 12:21 AM
mikefaster mikefaster is offline
The 3.3 liter engines are great and will last damn near forever, but you'll have to keep the oil in it... I just bought and flipped a 2001 Caravan that had a rod knock because the guy ignored a rear main seal leak...
You can get engines on ebay; I think there are several people in Minnesota that have them for $500 or even less... High mileage is fine if you want to get a cheaper engine; I put an engine in that had 166,000 (car had 146,000) and it ran mint because it was taken care of... Not bad for a $170 ebay special!
Then replace it yourself like I did, or pay a mechanic I suppose... Then sell it...
Mike
Old 12-23-2010, 08:08 AM
plymouthsrock plymouthsrock is offline
First, I would eliminate accesory drives as the cause by running the engine without the drive belt. Still got the noise, go to post #3.
Old 06-23-2011, 03:48 PM
mishalah's Avatar
mishalah mishalah is offline
What did you end up doing with your van?????
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 06:37 PM
2002 Toyota Tacoma 4 cyl engine knocking goldringer Tacoma 64 04-10-2010 11:59 AM
2002 buick century engine/ tranny in 96 cutlass supreme exit9teen88 Cutlass Series 3 01-26-2010 07:16 PM
1998 Mustang V6 engine knocks and runs rough birdstash Mustang Problem Diagnosis 2 06-04-2009 09:59 PM
2002 Maxima engine knock scottpull Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 06-13-2004 03:01 PM
