Go Back   Automotive Forums Car Chat > Pontiac > Torrent
Old 12-07-2010, 02:47 PM
slum_d0gg_ slum_d0gg_ is offline
Replacing Washer Pump
Hey Guys,
looking to replace the washer pump on my gf's 2008 pontiac torrent and just curious as to how difficult it will be.
best way to remove the w/w fluid resoiver tank or is there an easier access to the pump?
any help would be greatly appreciated!
Old 12-07-2010, 03:00 PM
danielsatur danielsatur is offline
Re: Replacing Washer Pump
Make sure you check the fuse, plugged,or Frozen window spray nozzel.
Can you hear the washer fluid motor?
Doe's your washer fluid have freeze protection?
Old 12-07-2010, 03:08 PM
yep, had the suv in a heated garage for 8 hours, checked line for freezing fluid none found. when depressing the fluid spray button, no noise is heard and no fluid being ejected! nozzles are clean and not frozen either!
fluid had been flushed to winter fluid prior to first snow fall!
still have to check fuse
Old 09-06-2012, 11:05 PM
thecrow1986 thecrow1986 is offline
also if your goin to change the washer pump get bthe revised/recalled rubber gromment that the pump sits into, the one with the filter is recalled because it clogs and blows the pump/and fuses
Old 09-07-2012, 11:36 AM
Tech II Tech II is offline
Two year old thread?
Replace 95 Town Car Washer pump Ronmc2256 Town Car 1 01-19-2007 09:16 PM
replacing windsheild washer pump??? jimmy snitch Tercel 2 03-07-2005 12:19 AM
How To Replace Washer Pump 98 Se Wulfenite29 Grand Prix 3 01-31-2005 06:57 PM
Washer Pump Replacement? miro1118 Jetta/Vento/Bora 1 02-03-2004 11:32 AM
