Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 02-10-2005, 02:43 PM
jimmy snitch jimmy snitch is offline
replacing windsheild washer pump???
I have a '92 4 dr tercel that didn't come with an owners manual.
Looking under the hood i couldn't make out where or what the pump even looks like. When the washer fluid button is depressed i get nothing, not even the sound of the pump attempting to function. I figure the pump is broken. Is this an easy fix, and is it an inexpensive repair???
thanks!
Old 02-16-2005, 05:13 AM
gator2764 gator2764 is offline
Re: replacing windsheild washer pump???
thanks!
Have not looked at mine but the pump might be built into the tank.
Old 03-07-2005, 12:19 AM
xzanth xzanth is offline
Send a message via ICQ to xzanth
hey
i had a problem with my washer as well, then i did some checking and looked at another car.... and found that the washer itself has 2 fuse like thingys inside it...... but no one sells these parts,,,
what i did is this....goto a car junk yard with lots of junked foreign auto parts and look and lookj for another toyota of the exact or almost same year... pop the hood, open the washer...no tools required.... and remove the fuse looking things... 2 small white things... then go and show the man behind the counter what you are buying... i paid less then 1 dollar.... and installed them in my car... no problems in 5 years..
good luck
