Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-06-2010, 06:05 PM
rook32 rook32 is offline
HELP water in plug wells
i have a 2004 v8 lincon ls ive had several missfire problems but after 2 coil packs and 3 double platinum plugs I had it running great. then after 3 weeks it started again, upon further inspection i found water in plug well 1 &2 any help is appreciated i dont understand how water could get in there, durring the last tune up i also got new covers .
Old 12-06-2010, 07:13 PM
danielsatur danielsatur is offline
Re: HELP water in plug wells
Water will roll from the cowl onto engine, run down the ignition buss lines, sneak under your COP cover, and flood the spark plug boss with water.
1) Use a shop vac + hair dryer for clean-up.
2) Dry COP's.
3) Make sure the rubber gasket is good on the COP cover.
4) Use a silcone sealent for the COP cover.
5) Do expecially the rear, were the ignition wires are going into the valve cover.
Old 12-06-2010, 08:08 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Is it actually cylinders 1 and 2 (first two on the passenger side nearest the belt) or 4 and 8? It would not be very likely that a cowl leak would make it to the front of the engine and not also impact cylinders 3 or 4.
-Rod
Water, water, everywhere....well only in the rear :) gw84 Lumina 16 09-06-2006 07:16 PM
Knocking noise, spark plug well oil puddle. Shpyder Eclipse Problem Diagnosis 7 08-05-2005 12:06 PM
oil in spark plug well truckpoor Tacoma 5 07-08-2005 10:50 AM
# 3 spark plug well full of oil cardsfan '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-27-2003 07:24 PM
