Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 08-29-2006, 03:24 PM   #1
gw84
gw84's Avatar
Send a message via MSN to gw84
Water, water, everywhere....well only in the rear :)
I'd like to dig up an old topic for a second. I was wondering if there were any new thoughts on the water in the rear floorboards of first gen. luminas? We just got a lot of rain in Southern Illinois and I had a nice surprise when I lifted up my rear floor mats. My in-car swimming pool is open for business!!!! As usual, the water is only on the driver's side in the rear. I did what I've been doing all along: Throw an Absorber in there to soak up the water. Anyone have any new breakthrough's on the topic?
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 08-29-2006, 04:10 PM   #2
maxwedge
A990 racer
Lightbulb Re: Water, water, everywhere....well only in the rear :)
Pull the seats out, rear firs,t pull the carpet and padding up and dry it out before mildew takes over, get in the car and have someone soak it down and see where it comes in, lots of possibilities here.
maxwedge is offline   Reply With Quote
Old 08-29-2006, 04:34 PM   #3
gw84
gw84's Avatar
If I get in the car soon after the rain, I can tell from the wet carpet, where it is coming from. There is a small "stream" of water that comes from the bottom of the door, down into the floor (I'll post a pic to describe this better). I'm wondering if it could be the weatherstrips.
Old 08-29-2006, 06:15 PM   #4
maxwedge
A990 racer
Look for blocked drains in the bottom of the door shell , or the paper/plastic water deflector in the door is missing or loose, behind the trim pad.
Old 08-30-2006, 08:06 PM   #5
gw84
gw84's Avatar
could you elaborate? What is the door shell? Here is a photo to help describe where the water is coming from: (The arrow shows the path, leading to the swimming pool)
Old 08-30-2006, 08:10 PM   #6
maxwedge
A990 racer
Door shell meaning the door itself, has drain holes below /behind the lower weatherstrip, if they are clogged the water builds up in the door and backs up into the car, as I said pull the carpets up and rear seats and water test for the source of the leak, no other way here, also as I said, mildew is an issue with water under the carpet.
Old 08-30-2006, 08:26 PM   #7
gw84
gw84's Avatar
Thanks! When the weather gets better here, I'll pull out the seats/carpet. I have access to lots of carpet pad, so replacing that won't be an issue . I have another issue with water in the vehicle, but maybe I should do them one at a time.
Old 08-30-2006, 08:28 PM   #8
gw84
gw84's Avatar
Everyone come play in the pool!
Old 09-01-2006, 07:50 PM   #9
gw84
gw84's Avatar
I just remembered something that may be the culprit. If you are referring to the plastic that is INSIDE the door, that probably is my problem. Right after I got the car, I had problems with the driver's side rear window (not going up/down). A friend of mine took the inside door panel off and slashed a rather large hole in the plastic "sheeting." I assumed that it didn't really serve a purpose, I got my power window fixed and left it alone. Could that be the prob? I really hope that's it; that would be a simple fix!
Old 09-01-2006, 08:35 PM   #10
maxwedge
A990 racer
Smile Re: Water, water, everywhere....well only in the rear :)
Could be, but again do the water test first, either way that has to be replaced.
Old 09-01-2006, 08:50 PM   #11
gw84
gw84's Avatar
how do I remove the interior moldings (the plastic parts along the bottom/sides)?
Old 09-02-2006, 09:22 AM   #12
maxwedge
A990 racer
Do you mean the sill mldings? If so they are hld in by clips, grab em' and pop em' off.
Old 09-04-2006, 08:12 PM   #13
gw84
gw84's Avatar
The part I'm referring to is the plastic that is just above the "arrow tail" in my picture. I assume I have to remove it to get the carpet up.
Old 09-05-2006, 06:51 AM   #14
maxwedge
A990 racer
Again, torpedo clips, just pull on the trim cover an they pop out.
Old 09-05-2006, 04:00 PM   #15
gw84
gw84's Avatar
Thanks! I'll give 'er a shot. BTW, Max, You sure are up early!
