Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-03-2005, 01:34 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Knocking noise, spark plug well oil puddle.
Very recently, my car has been making a rattling and ticking noise thats coming from the engine, for sure. Its exactly the sound you hear when a cylinder isnt firing. It appears during light acceleration at 10%-20% throttle, low RPMs. It actually sounds like a glorified lifter tick. I checked all my wires to make sure there was spark and found a puddle of oil in the well. Plus I'm pretty sure I've got nutty boost leak.
I'm going to get this stuff checked out soon, but some opinions/comments would be appreciated.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-03-2005, 09:33 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Knocking noise, spark plug well oil puddle.
Valve cover gasket is probably leaking, and that puddle of oil could be fouling out the spark plug i suppose. Interesting problem....
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-03-2005, 08:23 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
You know my car kinda makes a ticking sound when I start it up in the morning but after running for a couple minutes It stops, I wonder if it could be similar?
1991 GSX 2.3 Stroker
Old 08-04-2005, 12:24 AM
ted_ex's Avatar
ted_ex ted_ex is offline
I've heard of oil in the spark plug well causing a misfire. Try and listen to where in the engine the noise is coming from. If it's from the bottom end it could be trouble. If it's really loud it could be serious. Also check the oil for metal shavings.
tedX
I'm>everything
Old 08-04-2005, 04:04 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: Knocking noise, spark plug well oil puddle.
Yours sounds more like an oil pump that is shitting out.
Shpyer I don't know man. The only things that come to mind are head gasket and valve cover gasket. I'd hate to see your car out of commision, its just so fuckin sweet to look at. Hope you figure it out soon.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-05-2005, 01:03 AM
Shpyder's Avatar
Moderate moderator
The car was losing power and boost in all gears and RPM ranges when I took it out today, much worse than yesterday, and the knocking/ticking noise was louder and more pronounced. I am just so fucked. lol. We'll know tomorrow, but thanks for all the input guys!
Old 08-05-2005, 01:29 AM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
NOOOOO!!! Don't let the almighty super spyder die! lol. Hope it gets fixed soon, it's to pretty to be sitting on the side of the road out of commission.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 08-05-2005, 01:06 PM
Shpyder's Avatar
Moderate moderator
Not if I can help it, haha. Maybe I should set up a support group. Call 1-800-SHPYDER for further information on how to donate and help. lmao!
Well, the car went to the mechanics today. They are going to do an engine oil flush a few times. It could be loose valves, or just the lifters going bad...which I don't understand, since I had a valve job done only 10xxx miles ago! Hopefully the flush should cure the problem (strange though, since I religiously check my oil every day and top up whenever I need to), otherwise I need a new set of lifters.
