Old 12-04-2010, 09:40 AM
rhaltunen rhaltunen is offline
2000 Grand Prix GT: Did They Install a New Fuel Pump or Just Tell Me They Did?
I have a 2000 Grand Prix GT with the 3.8 liter engine. How can I tell if a new fuel pump was actually installed? I looked at the top of it from the access panel but can't really tell. It is an Airtex E3537M. They said they put one in but who knows?
Old 12-04-2010, 10:38 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: 2000 Grand Prix GT: Did They Install a New Fuel Pump or Just Tell Me They Did?
What was wrong with your fuel pump you replaced? Are you concerned that your replacement fuel pump is a used one? How much did it cost to replace it..
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 12-04-2010, 11:02 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Airtex is not a genuine GM part, so unless you had the pump replaced in the past with an Airtex, chances are they replaced it.
Plus if you can read the top of the pump after removing the access cover, then I'd have to say its been replaced. Usually they are so caked with dirt and dust that nothing it visable.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-04-2010, 11:32 AM
The car would barely start and when it did it would barely run. If you stepped on the gas from the parked position, it would stall out.
They told me the diagnostic tests(codes) were showing it was the fuel pump. I was concerned that they didn't replace it at all and just replaced some other inexpensive part but charged me $500 for a new pump.
After looking at it closely though, I do believe they gave me a new one. I was a bit concerned though because I just had them put in a new alternator for $220 and new upper plenum gaskets, valve cover gaskets and grommets, pcv valve, engine degrease for $750.
The car has 146,000 miles and is in good shape. I figured it was cheaper to have this work done than to go out and try to find a reliable used car somewhere. I have owned her since 2002 and am quite attached.
Old 12-04-2010, 11:34 AM
Good point. It was spotless and now that I look at it more closely, dirt and grime would definately get up there and show it's age if it was old.
Old 12-04-2010, 07:13 PM
Ralph123's Avatar
Ralph123 Ralph123 is offline
You should always tell the mechanic to save you all the old parts.
Old 12-05-2010, 10:04 AM
tblake's Avatar
In God We Trust
I find it odd that they told you that "codes" pointed to a fuel pump. There is not a single code that will tell you a fuel pump it bad. Maybe a fuel pump circuit, but even then, its only pointing to the relay control circuit. The PCM doesn't monitor the actual fuel pump circuit to my knowledge.
Have they or you checked fuel pressure?
Also try unplugging the MAF sensor and start it like that.
2000 grand prix stalls jay44 Grand Prix 51 03-01-2013 08:10 PM
2000 grand prix noisy fuel pump? xcmhs Grand Prix 1 06-22-2010 10:14 AM
installed new fuel pump, now runs rough mthc85 SC/SL/SW 3 11-03-2005 09:06 PM
installing new fuel pump?? Leesmack '88 - '91 Civic | CRX | Wagon | Shuttlee 12 01-29-2005 02:13 AM
Rattling noise after installing new fuel pump teresahornburg M Bodies 6 07-30-2004 09:04 PM
