Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-02-2010, 08:56 PM
Bspencer Bspencer is offline
wont start
96 crown vic started up sputtered like it ran out of gas and died tried to restart it and all i get is a whirring sound almost sounds like a grinding sound motor barely turns any ideas as to what might cause this thanks for any help.
Old 12-02-2010, 10:09 PM
danielsatur danielsatur is offline
Re: wont start
How old is the battery?
How about the fuel filter?
Old 12-02-2010, 10:14 PM
Re: wont start
battery is good and its getting fuel
Old 12-02-2010, 10:25 PM
Re: wont start
Is the starter solenoid enabling the engine to turn over?
Old 12-02-2010, 10:39 PM
Re: wont start
im not sure one guy told me it could be a timing chain broken any thoughts on that
Old 12-03-2010, 09:10 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: wont start
The engine does turn when you engage the starter but you hear a grinding noise from the engine while turning?
There's oil in it, right? If the timing chain broke, then it's likely shot. You'd have to replace pistons and valves on that bank at the minimum.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
