Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-02-2010, 10:51 AM
WarriorNJS11 WarriorNJS11 is offline
94 Dakota 2.5 broken cam shafts????
I have a 94 Dakota base model 2.5 4cyl...I had the cam shaft replaced at 166,000 miles when it just died while driving...3,000 miles later I have another broken cam shaft....I can understand the first one a bit, but the second in such a short time...Any ideas what could be the cause??
Old 12-03-2010, 12:39 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 94 Dakota 2.5 broken cam shafts????
only time a cam would break is if there are too tight a clearance between the cam and bearings or a lack of lubrication or a combination of the two. Make sure you don't have any sludge or anything that would clog the oil passages and cause the cylinder head to go dry.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-05-2010, 08:55 PM
urclueless urclueless is offline
Banned
cams break when people crank the snot out of the tensioner. but most common problem is warped head with misalignment on the bores AND i've seen a lot of broken cams due to improper assembly on the cam caps
92 dakota 2.5 no spark hambone403 Dakota 3 12-05-2010 08:53 PM
1990 2.5 NO spark in plug #3 and #4 UseDaGreyMatter Lumina 10 11-29-2010 06:57 AM
Broken Cam Shaft on '90 CRX DX gipson642002 Let's get Technical! 2 12-14-2009 02:06 PM
1991 Dakota 2.5 bucking and jerking debsco731 Dakota 2 11-16-2009 10:00 PM
2.5 turbo balance shafts ferretboy Lebaron 3 07-30-2007 08:49 AM
