Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-08-2009, 09:22 PM
gipson642002 gipson642002 is offline
Broken Cam Shaft on '90 CRX DX
I broke my cam shaft on my crx and was wondering if I have to swap the whole motor or if I can cut some corners and just replace a head or something.
Old 08-17-2009, 03:35 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: Broken Cam Shaft on '90 CRX DX
The block should be good unless you dropped a valve. Take your head off and inspect your pistons. And you might be able to buy a bare head, and re-use your valves/springs. Depends on the damage done by the cams.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 12-14-2009, 02:06 PM
RottenCRX RottenCRX is offline
The only way to tell is to take it apart. I'd say remove the camshaft, inspect for damage to the journals the cam seats in and if all looks good slap a "New-to-you" cam shaft in er. To bad you dont live near me i have one in my hand.
