Old 11-24-2010, 10:49 AM
dogkatcher's Avatar
dogkatcher dogkatcher is offline
Inline Heater Valve question .. had to cut it off, emergency fix
Is anything bad going to happen?
for the time being (job-sake), I just hack sawed the part off & clamped the heater core (in) hose to the metal T that connects to cooling sys
full story:
back for more issues, haha. thanks for the previous tips (90 XJ Laredo 4.0)
since its getting cold, figured I wanted to get heater running hotter. water pump has 30k, new bottle, hoses look good, flows good looking into bottle)
From what Ive read on here, sounds like a typical clogged heater core, I dont think its ever been "hot", since I bought it (w/ 108k)
I was trying to squeeze the core hoses to maybe unclog it; however, I
broke the attachment from heater flow valve to the core "in" hose, not sure why they made that half plastic but it was flimsy
the valve didnt look too good in the inside, almost looked stuck 1/2 open & almost deteriorated
for the time being (job-sake), I just hack sawed the part off & clamped the (in) hose to the metal T that connects to cooling sys
in hose gets hot, out hose is lukewarm
Main Question, is anything bad gonna happen from this ??
tryin to unclog core is next step
thanks
Old 11-24-2010, 01:42 PM
inafogg inafogg is offline
Re: Inline Heater Valve question .. had to cut it off, emergency fix
if i understand, you just by passed the heater control valve??
the hoses are still routed correctly 1 hose in 1 hose coming out
if so no problem with what you did,but still sounds like h/core is clogged
you can try flushing h/core in both directions when you replace the valve
btw what year is the car??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-24-2010, 07:30 PM
dogkatcher's Avatar
90 cherokee laredo 4.0, 145k (I have no repair history before 108k) I did water pump about 120k
BIG QUESTION
Are the nipples / hose attachments from heater core usually metal or plastic? im almost certain its stock .. hard to tell what its made of, hoping metal
dont wanna bust plastic parts again, when I goto remove the hoses to it
I live in an apartment w/ garage to work in, not sure how to flush it since I dont have access to a garden hose .. still pondering that one .. Im gonna start by removing hoses & checking the ports for blockage
definatly need to fix heater asap .. subzero temps are coming soon, going ice fishin this weekend too
Old 11-24-2010, 07:41 PM
well good luck fishing,i used to but in summer & about 75 miles offshore
anyway i would treat the connectors as plastic, very brittle in cold weather
use a razor knife to cut & peel hose off
mine, a 98 g/motors was but i did'nt no & cracked h/core
not sure about the 90
good luck mike
Live For Today
Yesterday is gone,
Old 11-24-2010, 10:03 PM
dogkatcher's Avatar
good luck mike
good to know, thanks .. hindsight can be brutal
just need to get the new hoses to replace (just in case), not much room left to work on shortened hoses, its a tight fit in there
I barely maneuvered the "now" shortened bypassed line to fit in there, & moved other hoses around.. doesnt look stock anymore
Old 11-25-2010, 04:11 PM
just in case, im not sure of your set up & not sure what where you cut
i would'nt say heater core is bad yet until you replace the control valve
& flush system.
happy thanksgiving,mike
Live For Today
Yesterday is gone,
heater valve question moliva1568 Caprice 14 01-09-2010 12:07 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Fuel Cut Off To Early. Cut Off At 6500rmp outsider6 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 08-08-2007 04:39 PM
Diesel : No juice to my cut off valve Jetta3us Jetta/Vento/Bora 4 03-22-2005 05:49 PM
Heater output cut off gc2139 Rodeo | Passport | MU 0 06-24-2004 03:51 PM
