Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 11-24-2010, 08:17 AM
SCJake SCJake is offline
oil leak
im leaking oil. not a big deal but use ur resources though right? so anyone know of any common places that the 5sfe tends to leak oil? was gonna give the engine a once over this weekend and figured i could save myself a lot of time if someone could point me in the right direction
Old 11-24-2010, 10:11 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: oil leak
Most common leak sites are:
1) Valve cover gasket
2) Camshaft oil seal (behind timing belt cover)
3) Oil pump shaft seal (also behind timing belt cover)
4) Front Crankshaft oil seal (ditto)
5) Head gasket
6) Rear crankshaft oil seal
#1 is an easy fix...purchase a valve cover gasket set. It'll come with seals for the spark plug tubes. You'll need some oil resistant silicone sealant to dab into a few corners as well. Torque the tube nuts to 17 ft-lbs.
#2 through 4 are usually done along with a change in the timing belt. Good idea to plan all this work at once because it involves some teardown of the front of the engine. Some change the water pump, idler pulley, and tensioner too for the same reason.
#5 not so easy...that's why down on the list. The camshafts have to be removed to get to the head bolts. Let's not go further into it unless necessary.
#6 also not easy...engine removal required. Enough said.
Hope this helps
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-24-2010, 11:49 AM
Re: oil leak
k. thanks. at least now i got some pinpoint sites to look at. hopefully its one of the easier ones
Old 11-29-2010, 02:28 PM
Re: oil leak
k. so i ripped it apart and found nothing. i took of the original intake and put in my own with a breather cap. could the smell just be from the cap being open now and not being fed directly back into the engine? its a very faint smell so im thinking that could be it
Oil Leak after Drive Thru Oil change Bill-SILV F Series 8 12-23-2009 06:54 AM
Oil Leak in radiator Southern Comfort Camaro Discussions 2 07-26-2009 09:40 AM
Head gasket oil leak...stop leak products? indyc280 C-Class 3 03-17-2009 11:57 PM
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
Oil leak and P/S leak rbsteve Escort 0 11-07-2005 02:44 PM
