Old 11-20-2010, 05:41 PM
griffdus griffdus is offline
Send a message via Yahoo to griffdus
87 f150 no start
got a 87 F150 doesnt turn over at all . replaced ignition switch , checked all fuses, replaced celenoid, if u jump celenoid starts everytime just wont start with key. all lights and everything turns on with key also anyone got ideas?
Old 11-20-2010, 06:16 PM
ctwright ctwright is offline
Re: 87 f150 no start
Hi, just read your post, you say all the fuses are good, you should have a red/light blue wire going to your clutch interlock switch(if manual) or neutral safety switch(automatic), check for voltage. If so, check the opposite side of the switch with the clutch depressed(manual) or in park or neutral(automatic), for voltage. If no voltage replace the safety switch or clutch switch, whichever you have(provided you are getting the supplied voltage to the switch). If voltage there then check for voltage on the same color wire at the solenoid . If not there trace the wire back until it runs in the passenger compartment under your dash for breaks in the wire.
Old 11-23-2010, 10:54 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
" replaced celenoid, if u jump celenoid starts everytime just wont start with key"
Starter selenoid? starter relay? is that what your talking about? if so one way to bypass and fix run a new ignition/key to starter relay (had to do it to my 88 as well)
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
92 f150 starting problem kukidude F Series 2 11-23-2010 12:29 PM
1990 F150 starting issue - key start position problem, and jumping with solenoid mounddog F Series 2 08-20-2008 02:10 AM
1992 F150 starting problems dirtrider2002 F Series 6 02-20-2005 07:03 PM
1985 ford f150 starting problems jka F Series 4 08-16-2004 05:30 PM
92 ford f150 starting problem!!!!! helllllppp!! thunderbird muscle F Series 6 06-21-2004 07:46 PM
