Old 11-14-2010, 08:18 PM
nater1 nater1 is offline
GP wont start
i have a 99 GP SE, it has 196,xxx miles. i had the head gasket, and intake gaskets replaced. I drove around for about a week after i had them replaced, then about 400 miles to school, and it worked fine, then i went out the next day and it started but was smoking badly and it smelt like burning coolant so i shut it off. I went out later and it woundn't start. it has spark and is getting gas, but it won't turn over. i know it has a bad cps and maf, but those are the only codes. if anyone know what might be wrong plase let me know. thank you.
Old 11-14-2010, 11:12 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: GP wont start
3100 or 3800?
when you did the headgasket, was there oil in the water?
Old 11-14-2010, 11:49 PM
Re: GP wont start
its the 3800, and no i there wasn't oil in the water
Old 11-15-2010, 09:00 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: GP wont start
So the motor cranks or not? Was the upper intake manifold inspected and/or replaced when the head gaskets were done? Its possible the Upper intake melted and allowed coolant to fill combustion chambers. This could hydrolock a motor and could cause serious issues like bent connecting rods.
If the car doesn't crank, I'd remove the spark plugs and then see if you can crank it over.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-15-2010, 12:38 PM
Re: GP wont start
this is what I was thinking Tim, but he indicated there was no water in the oil. We'll see if the car turns over or not...
Old 11-15-2010, 03:11 PM
Re: GP wont start
it does crank, i think the uim was looked at, but i dont think he took any measurements on it.
Old 11-16-2010, 09:08 AM
tblake's Avatar
In God We Trust
Re: GP wont start
If your coolant level is good, and oil looks good, I'd focus on the CPS and MAF codes. Do you have spark at the plugs?
Old 01-01-2011, 09:08 PM
Re: GP wont start
i replaced the sparks plugs, and it runs now, kind of ruff though. i got another code reader on it and said i have a misfire, how can i fix that.
Old 01-06-2011, 05:54 PM
tblake's Avatar
In God We Trust
Re: GP wont start
You have to figure out why its got a multiple cylinder missfire. Low fuel pressure, plugged cat, vacuum leak....
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
