Old 11-12-2010, 10:22 PM
Firstymer Firstymer is offline
Unhappy HELP: Installing aftermarket radio
I need help installing an aftermath radio into my 00' Pontiac Grand Prix SE V6 3.1L car. I am aware I need the wire harness and in-dash kit which I can purchase at Walmart relavently cheap, but is there anything else I need to know before I attempt this project? i.e. how to remove the oem radio from the car?
Old 11-13-2010, 08:54 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: HELP: Installing aftermarket radio
The oem radio comes out very easily. Remove the dash bezel (the big plastic piece that goes around the instrument cluster, radio and HVAC controls). Put the tilt wheel in it's lowest position, and be careful so you don't crack the bezel or snap off the hazard switch button while removing the bezel. If you have fog lights, you'l have to unplug the fog light switch as it is attached to the bezel . The radio itself is secured by screws on each side of the face. Follow the directions on your wiring kit to wire up your new radio, put it in the adaptor kit, and install.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-13-2010, 09:35 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I usually remove the two bolts by the drivers knees holding the lower panel on. The pop the panel off, and the the dash bezel should come out pretty easy.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-17-2010, 04:28 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
My first a/m radio install was on my GTP. I was pleasantly surprised how easy it was. The hardest part, I thought, was splicing the wires for the harnesses which was pretty simple.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 11-17-2010, 08:15 PM
doctorhrdware doctorhrdware is offline
You also need need the GM antenna adapter. The antenna connector is smaller then the aftermarket radio antenna connector. It will be fairly easy to take the OEM radio out and install the aftermarket radio in.
Installing Aftermarket Radio illuzionx7 '97 - '03 1 02-02-2008 11:53 PM
97 Bonneville Won't Start After Installing Aftermarket Radio 1997bonneville Bonneville 3 01-21-2006 09:48 AM
Install Aftermarket Radio in 2000 Impala emsp80 Impala | Impala SS 5 01-13-2005 12:56 AM
HELP!!! Installing aftermarket radio 2crunk Off-Topic 14 09-03-2004 05:28 PM
Help installing aftermarket radio xjryan Off-Topic 4 07-30-2003 01:26 AM
