Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 06-25-2006, 09:10 PM
illuzionx7 illuzionx7 is offline
Installing Aftermarket Radio
I've recently been trying to install my pioneer aftermarket radio and removed the stock monsoon updgraded radio from my 2003 Jetta GL. I wired up the pioneer radio and everything works fine except one problem. The power stays on for the radio all the time even when I pull the key out of the ignition. I tried the ignition wire with nearly every wire but nothing is solving the problem. If anyone has any solutions to this problem please help! Thanks!
Old 02-02-2008, 10:53 PM
15bigfoot 15bigfoot is offline
Re: Installing Aftermarket Radio
You have 1 wire in the original wiring for the radio that is hot all the time.That wire is for memory.1 wire is hot only with the key on,that is for radio on & off. Or you could just try turning it off manually(the radio).
