Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 11-08-2010, 05:28 PM
retrohwam retrohwam is offline
2004 2.4l fan clutch removal
Working on my son's 2004 Frontier with a 2.4l. Replacing the water pump and having trouble with removing the fan clutch attached to the front of the pump.
First question: are the nuts right hand or left hand thread? I can't seem to break them either way and I've started to round the corners of two nuts.
Second question - are the nuts 10mm? I'm using a 10mm tubing wrench and it seems to be correct but it's not quite tight.
Any help would be appreciated -
Thanks,
Duane
Old 12-18-2012, 01:21 PM
Cusser's Avatar
Cusser Cusser is offline
Re: 2004 2.4l fan clutch removal
Well, I hope you got this completed by now. I've done this job on a 1998 with that engine, and it was straightforward. I used a 10mm box wrench, and the threads are typical right-hand threads. It is a little cramped.
2.3 fan clutch removal direction? btroy Ranger | Courier 8 07-06-2009 08:36 PM
Is it possible to replace connecting rod bearings on 2.4l w/out removing engine!? liquidmxz Cavalier Problem Diagnosis 1 03-10-2009 09:31 PM
will a 2.4l nonturbo clutch fit in a 2.0l non turbo clipse420a Engine, Transmission and Drivetrain 5 03-11-2008 03:20 PM
Fan Clutch Removal porsch964 Rodeo | Passport | MU 1 03-14-2005 07:49 AM
1999 S10, 4.3 Fan Clutch Removal!! Help Please zzr7ky S-10 4 10-29-2004 03:08 AM
