Old 10-21-2004, 08:19 AM
zzr7ky zzr7ky is offline
Question 1999 S10, 4.3 Fan Clutch Removal!! Help Please
Hi - I'm trying to replace a failed Water Pump. I have the tool to remove the fan clutch asm from the threaded portion of the water pump. However, the nut is stuck on hard enought that the belt tension will not allow the fan clutch to be removed.
Is there a better way to secure this. I'm letting it soak today with Kroil. I did warm it a wee bit yesterday. Tonight it needs to come off.
The Chilton manual isn't much help in this.
Thanks,
Mike
Old 10-21-2004, 08:51 AM
Fireplug Fireplug is offline
Re: 1999 S10, 4.3 Fan Clutch Removal!! Help Please
If I remember I think it has left hand threads. clock wise to remove.
Old 10-21-2004, 08:57 AM
Exclamation Re: Re: 1999 S10, 4.3 Fan Clutch Removal!! Help Please
Originally Posted by Fireplug
If I remember I think it has left hand threads. counter clock wise to remove.
Wow!
I'll be a bit embarassed if that's the case. I did look at the threaded section on the new water pump but I could have 'seen' what I was expecting - RH threads. I'll look closer tonight.
Mike
Old 10-22-2004, 07:12 AM
Talking Got it!
Hi - It is a standard thread. I ended up backing out one of the bolts to the water pump pullyabout 3/8ths" and then put my 1/2" open end on the next bolt. Slipped a pipe over the wrench as it bore against the backed out bolt. This stopped the waterpump from turning. Came right off.
One hour job it done correctly!
Mike P
Old 10-29-2004, 03:08 AM
davydawg davydawg is offline
Send a message via AIM to davydawg Send a message via MSN to davydawg
i could not get mine off, so i removed the water pump with the fan still on, smashed the old water pump, then put it in a vise, then i was able to get it off. the threads were all rusty. i had to remove radiator too. which was nice because there was a lot of crap blocking my air flow
