Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 11-08-2010, 04:18 AM
RevelationX RevelationX is offline
2000 Desert Runner misfire
Basically I'm looking at buying this truck. it is the 2000 SE Desert Runner man. trans.
On the test drive everything worked/sounded great excepting that it has a misfire/stumble under load. no SES/CEL, I talked to the dealer and he said after they detailed it that it sounded rough even at idle but chalked it up to wet from the washing..and it does idle fine as of now..when inspecting after the test drive I noted it sounded like an exhuast leak on at the rear of the passenger engine bay. After a little research it seems the manifold is the usual suspect..is the misfire a symptom of this or should I/He be looking at blasting the dizzy cap and such with some w.ater d.isplacing stuff also ?
thank you and sorry it's a long post.
Keith
2004 desert runner wulam Frontier | Navara 0 11-15-2009 09:27 PM
2001 Desert Runner (2wd/LB) exhaust djalban Frontier | Navara 3 12-30-2007 04:41 PM
Desert runner tblack Cherokee 6 03-26-2005 12:34 AM
How do I get the molding off of a 2000 Desert runner bumper / so that I can paint it? Silverman Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 06-24-2004 04:03 PM
P\N for Desert Runner rims? Stormy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 01-23-2002 09:07 AM
