Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-06-2010, 03:27 PM
dmack31 dmack31 is offline
replacing ignition switch actuator 96 cougar
I bought a theft recovery 96 cougar and need to replace the ignition switch actuator. I have dropped the steering column and tried to remove it from the read and it will not come out. Do you need to remove the steering wheel to replace this part. If so I have searched but being new today have not found a repair manuel for this model is there a place on this site where I might look.
Don
Old 11-11-2010, 11:03 PM
Davescort97 Davescort97 is offline
Escort guy
Re: replacing ignition switch actuator 96 cougar
Welcome to automotive forums!
You might try www.autozone.com They have online repair guides for most older cars.
Old 11-12-2010, 09:17 AM
Thanks for the reply but have done that as well as go to the library and looked thru the chiltons and haynes manuals, neither of them cover this. From what I could see, will have to take the column out and then loosen the shaft from the bottom so that I can pull the tilt head out far enough to get the actuator out the back side and replace it.But it got cold and snowed so I will start it with the screwdriver till it warms up a bit. Hate working in the cold.
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
Windstar ignition switch actuator jalalt Windstar 1 09-12-2007 09:22 AM
95 CV Ignition Switch Actuator lever/rod replacement? SaveDinero Crown Victoria 0 03-01-2007 05:29 PM
Ignition switch actuator rod raymerc Grand Marquis 2 08-16-2005 09:45 PM
