Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-13-2005, 05:14 PM
raymerc raymerc is offline
Ignition switch actuator rod
Has anyone changed or purchased the actuator rod. The engine will not cut off without disconnecting battery. Ignition lock and switch ok. Need help!
Old 08-13-2005, 05:21 PM
The above post was for 96 GM
Old 08-16-2005, 09:45 PM
Found the problem and fixed. Pulled the steering column out and disassemblied to find that the pin that holds the acuator arms together had come out. The fit was still tight ,so reinsalled pin and reassemblied. Probably saved $400 plus in labor and parts.Parts being only about $25.
