Old 11-05-2010, 11:52 AM
jlemay jlemay is offline
2000 s-10 Vortec bad fuel economy
2000 S-10 ZR2, 3 dr, 4x4, Vortec V-6, seq injection, 3:73 rear gears, gears between rear and trans act like low gears thou, @55 mph runs at 1700 rpm, fresh oil in all pumpkins (synthetic), plugs and wires look like new
1. What is the MPG supposed to be for this truck?
2. Would duel exhaust improve MPG, and how much?
3. Would any add on after market parts improve MPG and how much?
4. Brand new Goodwrench tires with appropriate size for truck by door panel.
5. Engine runs good, dont miss, good power, etc, so i think the compression is decent.
edit:
1. automatic
2. 105k miles
3. bought about 6 months ago, no tune up done
4. donno brand name used atm
5. 3 new oxygen sensors
6. have not checked fuel pressure/leakdown, but truck runs like a top, dont miss etc
7. new air filter
8. will replace fuel filter in about ohhhh, 10 min, lol
9. no SES codes going on
If i did a tune up what would you suggest?
edit 2:
fuel pressure perfect and does not have a distributor cap, but coil instead
Old 11-05-2010, 05:26 PM
old_master's Avatar
Advisor/Moderator
Re: 2000 s-10 Vortec bad fuel economy
Manual or automatic transmission?
How many miles on the vehicle?
How many miles since it was last tuned up?
What tune up parts were replaced?
What brand of parts were used? (4.3L is fussy)
Have the oxygen sensors been replaced?
Have you checked fuel pressure and leakdown lately? (Must be within specs)
How many miles on the air filter?
How many miles on the fuel filter?
Is the Service Engine Soon, (SES) light on or does it blink when accelerating?
If so, have you retrieved any Diagnostic Trouble Codes, (DTC's)?
You have to know how it works,
to figure out why it doesn't.
Old 11-06-2010, 03:35 PM
old_master's Avatar
Advisor/Moderator
It's due for a tune at 100,000 miles. I would recommend AC Delco 41-993 plugs with a gap of .060". These things are real fussy when it comes to caps: AC Delco distributor cap and rotor, put a dab of silicone dielectric grease on each terminal, inside and out, of the cap. While the cap is off, make sure the vents are clear, (no debris). Autolite Professional Series plug wires, (better and cheaper than AC Delco). Fuel delivery is critical on these engines, low pressure or excessive leakdown WILL cause problems. The fuel pumps are good for around 100,000 miles. If/when it needs a pump, don't cut corners here, AC Delco or Delphi ONLY. To check fuel pressure and leakdown: ignition in RUN position, engine off, fuel pump running, pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes.
Old 11-20-2010, 11:09 AM
updated, check top post, can only update when im off work, etc
Old 11-20-2010, 11:36 AM
old_master's Avatar
Advisor/Moderator
2000 4.3L has a distributor, and a cap and rotor. It's right next to the fuel pressure test port, can't miss it.
Old 11-21-2010, 02:01 AM
viggy58 viggy58 is offline
what kind of mileage are you getting?
i get 22-25mpg, but i have a 2wd 5 speed. you should prob expect 16-20mpg depending on 4x4 usage, i would assume
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
1990 740 GLE rough and bad fuel economy - help! brianm_14 General Discussion 2 07-11-2005 10:51 AM
Bad Fuel economy causes? cantrol Escape | Maverick | Escape Hybrid 3 05-31-2005 01:31 PM
bad fuel economy mazzaman Accent | Verna 1 03-04-2005 08:09 PM
96 Sunfire running cold, bad fuel economy, Fan always on Snowflake Cavalier Problem Diagnosis 1 01-10-2005 12:38 AM
Legacy GT A/T bad fuel economy AzumiRM Legacy / Liberty / Baja 1 11-06-2003 06:53 PM
