Go Back   Automotive Forums Car Chat > Suzuki > Aerio/Liana
Old 11-03-2010, 11:03 AM
josem josem is offline
aerio air filter problem
I have an Aerio 2004 with 162000 miles, original owner. Recently change the air intake with a hi performance system. Now I am getting occasionally the P0171 and P0101 codes lean mixture and mass air flow range/performance. Any idea to correct this problem.
Old 11-03-2010, 11:27 AM
Scrapper Scrapper is offline
AF Premium User
Re: aerio air filter problem
some of those maf sensor you can take apart and clean the screen. but now i think they figured it out so there putting weird screws or torx socket. if you cant clean it there not hard to put on. have you tried reseting computer by taking neg. cable off for about 10 to 15 mins. then hook it back up?
K&N Engine Air Filters - Worth It? RidingOnRailz Engineering/ Technical 9 06-24-2011 10:34 AM
Air Filter. Recommendations? xephornite Aveo 5 07-10-2010 06:42 PM
Why you should check the air filter occasionally james_smart Engineering/ Technical 6 12-31-2009 04:06 PM
backfirea and caught air filter on fire!!!! davidrobert2 LeSabre 8 03-27-2009 08:22 AM
dual carb air filters problem? civic_racer_dualcb '88 - '91 Civic | CRX | Wagon | Shuttlee 2 01-29-2004 05:06 PM
