Old 10-23-2009, 08:36 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool K&N Engine Air Filters - Worth It?
Is there a noticeable performance difference with these air filters? Is it worth the extra money plus periodic cleaning and applications of a "special oil" lubricant?
Old 10-23-2009, 10:46 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: K&N Engine Air Filters - Worth It?
If you have a Honda S2000 that regularly sees 9000 rpms you might notice a performance difference. However, on most cars driven under typical conditions the difference will probably only be in sound of the intake, if any. The main benefit to the K&N filter under typical applications is the longevity of the filter. It likely will pay for itself over the life of the car, but you need to be very careful to not over oil it after cleaning. If you over oil it, the excess oil can easily accumulate on the MAF sensor and cause fuel economy concerns. Most folks agree that the airflow benefit happens only at very high rpms, ranges in excess of typical urban driving.
-Rod
Old 10-24-2009, 02:30 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I have used many K&N's over the years. Often they do not have much benefit over a good quality, reasonably clean paper filter.
Their greatest advantage is with custom intake set-ups. They have a wide variery of shapes and sizes that can fit just about any custom intake set-up, including compact ones for where space is at a premium.
Their greatest disadvantage is they are not very good at filtering air, regardless of their advertising.
I have placed a thin film of oil or grease on the side of the air filter housing, where the air should be clean. With a stock paper filter, the grease stays clean. With a properly-oiled K&N, the grease gets dirty and gritty, over time, from dirt that is sneaking past the K&N.
Old 10-24-2009, 11:41 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
It completely depends on the vehicle. Some stock intakes are remarkably restrictive, others are more than adequate. One thing that does tend to happen with the oiled cotton filters is that they sacrifice filtering for flow. They tend to let more particles through, especially as they get dirtier.
The latest technology has filters that don't use oil impregnation to trap dirt. They flow as much as a K&N, but filter much better. AFE is one company that has dry filters that flow a lot but don't need oil.
Dragging people kicking and screaming into the enlightenment.
Old 11-21-2009, 07:22 AM
dizzle1's Avatar
dizzle1 dizzle1 is offline
I used a cone filter from K&N the RE-9020 along with a 90 degree elbow and some 3.5 inch piping to make my CAI. These are the things that I noticed better throttle response, car felt more energetic, sounded like it was revived much better than with the muted sound it had with the stock air box.
But the filter does get dirty after time and oil on the MAF could lose you mpg so I check that out and clean it but half the time it’s not even dirty. I cleaned my filter at 100k now im at 108k so I might clean it again, but I’ll see what K&N recommends on the schedule cleaning of their filters. In the mean time ill take what I learned from here and see if it applies to my dirty looking filter.
Old 04-27-2011, 12:50 AM
DropZone77's Avatar
DropZone77 DropZone77 is offline
This is the kind of K&N filter system that gives your somemore hpower
Old 05-01-2011, 11:48 AM
sracing's Avatar
sracing sracing is offline
We have tested (flow bench and dyno) several filters and cold air inductions systems. (I have to disclose that we are K&N Distributors.)
K&N does disclose on each of their units what the expected HP gains will be over stock and they are pretty close based upon our tests. You can usually expect 5 to 15 HP depending up the vehicle. A couple points: They show the gains with STP correction factors. These usually are about .05 percent higher than SAE gains. (Not a big deal.) Also, these gains take place at and beyond peak torque range. So you certainly aren't going to notice anything in the seat of your pants in normal driving.
One other thing: In spite of what Al Gore might have told you, changing your air filter does not increase MPG on any later model fuel injected car. It can help on a carb'd car.
K&N's are very well constructed and designed and are typically a good investment due to longevity.
Old 06-24-2011, 07:28 AM
lootzy lootzy is offline
thats hitting it perfect, be carefull becouse alot of the k&n filter lets more particulates through and some vehicles use a plastic intake manifold and over time the particulates act like sandblasting into the air intake into throttle body causing damiging results to the intake
Old 06-24-2011, 08:43 AM
danielsatur danielsatur is offline
What's easier to breath through, paper or cloth?
A Sham Wow with a little fogging oil works too!
Old 06-24-2011, 09:34 AM
Scrapper Scrapper is offline
AF Premium User
-Rod
i agree on that on to much oil i work on a friends ranger and she never told what her son had done to it and it pluged it up.
Tags
air , filters , k&n
