Old 12-26-2009, 08:25 PM
james_smart james_smart is offline
Thumbs up Why you should check the air filter occasionally
You should check the air filter occasionally. This may require a screwdriver. Look for the air intake, the hose is usually the biggest ones under the hood that does not connect to the radiator. If you hold the filter up toward the sky you should be able to see light through it. Bang it on something to knock some dirt out of it.
unauthorized link removed by Moderator.
Old 12-28-2009, 07:33 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Re: Why you should check the air filter occasionally
Good tip!
My car was hard-starting during the last two months. Changed EAF for the first time since last winter, hard-starting gone.
Old 12-28-2009, 07:44 PM
danielsatur danielsatur is offline
Yep! You can find lost horse power by replacing a bad air filter + cleaning the MAF & IACT sensors.
Old 12-29-2009, 08:37 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Change it every 15000 miles (25000km)* and you'll never have to worry.
Or get a K&N filter and clean it every 30000* miles.
*more often if you drive in dusty conditions. Some people hate K&N.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-29-2009, 09:12 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The big caution with the K&N and similar oiled filters is you need to be very careful not to over oil them. If you don't get the oiling just right after cleaning, they can easily coat the Mass Air Flow sensor elements and cause fuel economy issues along with other driveability concerns.
-Rod
Old 12-29-2009, 09:31 AM
-Rod
Yup....because some eeediots can't follow the simple directions!
Old 12-31-2009, 03:06 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Never bang the air filter on anything to knock dirt out of it, when larger particles are caught in it, they can make a small hole in the filter material. Doing anything to remove dirt from them can potentially leave small holes that smaller particles can flow through.
-Rod
Most of them also have fairly large holes in the filter, holes big enough to see through... I don't mean see light, I mean see how many fingers someone is holding up. Many air intakes that have K+N filters before them have a very fine coating of dust lining the sides... and the MAF sensor.
I'm not saying they're bad, they have their place, I have one on my truck. I also have a second paper filter. The K+N is great for catching a lot of the dust encountered while offroading (and not having to replace the filter after every-other trip), but the paper filter still gets very dirty.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Tags
air , car , filter
