Old 11-01-2010, 07:51 PM
Scuzz Scuzz is offline
Can't resolve turn signal/brake light problem.
I pulled a trailer for first time with my 98 S10 and the right rear brake light and turn signal will not work now. Left turn signal blinks perfect but right side blinks in dash really fast and front light blinks twice as fast, but right rear does not blink or brake light comes on.
I checked right rear bulb, which was okay, but I replaced it anyway. Everything else is okay.
I can't figure out where to trace it back to.
Found a wire on right side trailer light shorted out, so I figured I've blown something.
Thanks to all who read this and maybe someone can point me in right place to look.
Old 11-02-2010, 12:23 AM
viggy58 viggy58 is offline
Re: Can't resolve turn signal/brake light problem.
might have toasted the relay... i cant tell you off the top of my head where it is, but as a test, swap the left and right, or swap the bad side with the hazard relay... that will let ya know if that is where the problem is.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 11-02-2010, 09:34 AM
Kinda what I was thinking. I should be able to find all that under dash. I'll get my manual out and look tonight.
Thanks,
Ron
Old 11-02-2010, 01:14 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You may have blown a fuse or burnt a wire.
Is both/all brake lights gone?
On right rear turn signal check for 12 volts to it and good ground.
Let us know what you find there.
MT
Old 11-02-2010, 01:15 PM
MT-2500's Avatar
AF - Advisor
Also if you have wired in a trailer plug check wiring and connections to it.
MT
Old 11-02-2010, 01:41 PM
First thing I did was check all fuses. All good. Then opened up tailight and checked bulb, which looked good.
I then checked voltage to bulb, I had none.
Went ahead and put in new bulb while I was there and mounted light back in bed side.
I also got under truck and unplugged pigtail that I bought for trailer lights thinking it might be the problem. Plugged stock harness back together and still nutin'.
Been a Honda guy so long I forgot my Chevy roots on trouble shooting.
Old 11-02-2010, 04:53 PM
old_master's Avatar
Advisor/Moderator
The T/S flasher unit is used for both sides, so if the left side works, that's not the problem. With the ignition in the RUN position and the right turn signal ON: Check both terminals of fuse #16 (10 amp) in the underhood fuse panel with a test light or voltmeter. It should blink. If only one side blinks, the fuse is bad. If it doesn't blink, the problem is in the multifunction switch or the wiring from the multifunction switch to the fuse. Post your results.
You have to know how it works,
to figure out why it doesn't.
Old 11-02-2010, 05:23 PM
inafogg inafogg is offline
had simular, look at the connection where the trailer harness connects
to the brake/turn in truck harness
the lamp side of harness was'nt getting 12v (the connection was faulty on mine)
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-02-2010, 07:57 PM
Dumb question.
Where's the multifunction switch?
Thanks,
Ron
Old 11-02-2010, 09:27 PM
old_master's Avatar
Advisor/Moderator
The multifunction switch is in the steering column cover, the turn signal lever attaches to it.
Old 11-03-2010, 06:56 AM
MT-2500's Avatar
AF - Advisor
Lot of stuff built into that one switch.
Tell us where you are at on testing.
Have you been to the right rear turn signal fuse and checked for voltage both sides and flashing or just on or off?
If not to test the multi function switch you will need to get a wiring diagram on it and find the wiring harness on bottom of steering column.
Check and see if you have right rear turm signal voltage out of it.
MT
Old 11-03-2010, 07:02 AM
MT-2500's Avatar
AF - Advisor
COMING OUT OF MULTI FUNCTION SWITCH.
Dark Green/white wire is right turn and yellow wire is left rear brake and turn signal.
A 12-15 voltage volt meter or a old type bulb test light will check it for you.
Good Luck and
Let us know what you find.
MT
Old 11-03-2010, 08:52 AM
Man, I really appreciate all the help.
So the turn signal switch is now called multifunction switch.
I'll get my repair manual out today and chase it down.
All my GM work has mostly been from 60's and 70's.
Somewhere in the late 70's, I got on foreign stuff, but I'm also back to GM now.
I've built half dozen streetrods in last 18 years with fuel injection, overdrives and such, but all with basic aftermarket wiring harnesses like I grew up on.
I'll see what I can do today and get back.
Again, thanks a million for all the tips.
Old 11-03-2010, 09:27 AM
MT-2500's Avatar
AF - Advisor
Yes.
Dimmer an washer wiper and and turn signal and cruise are all made in one switch.
If one part of quits it is replace the hole thing.
But check that fuse for power both sides and wiring first.
Some switches will cost a arm and a leg
MT
Old 11-03-2010, 04:14 PM
Nice of GM to help us out like that.
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 01:39 PM
1998 Lumina turn signal/Brake light problems jbach4 Lumina 4 11-11-2007 08:21 PM
turn signal / brake light problem dherzog79 Problem Diagnosis 4 04-12-2007 02:42 PM
96 Jetta Electrical Problem turn Signals/Brake lights Murano '91 - '96 1 09-11-2006 03:56 PM
2000 Ranger Turn signal/Brake light/hazard light problem geminidustin Ranger | Courier 3 10-31-2004 06:47 AM
