Old 10-30-2010, 05:13 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
1997 Grand Prix 2 door window problem
Hello guys, I'm very happy to drive my GP again! I had it re-aligned today and got the ball joints replaced too, one of them had some slack so I decided to have both replaced...
Now my problem is that the passenger window is leaning to the front of the car when you roll it up, you have to give it a hand and hold it against the back or else it won't close, is this a loose bolt/screw causing it to lean forward?
I tried to remove the door panel, but couldn't find a way to do it, I took off the 2 torx screws by the door handle but else from that I couldn't remove it I was so afraid that it would brake that I wanted to ask first.
Thanks in advance for any help, best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 10-30-2010, 06:22 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: 1997 Grand Prix 2 door window problem
sounds like the window came off track. fairly easy fix.
the door panels aren't all that hard to get off. Just pull real hard on them, forget about trying to save the clips...you're going to break a few of them regardless.
you can get new door clips at the local parts store for fairly cheap.
Old 10-30-2010, 06:30 PM
BNaylor's Avatar
BNaylor BNaylor is offline
It sounds like the power window regulator has an issue. Most likely worn out or out of place Bowden cables or plastic clip broken off the window mount which is still part of the regulator assembly. You can get a regulator with or without the drive motor since the drive motor isn't the problem. Once you get the door panel off just do a visual inspection first.
On the door panel you have to pull the panel off starting at the bottom of the door panel and working your way up. There are several push pin plastic clips that hold it to the door frame. You may need to get replacement push pins since some will break. Dorman makes GM generic. The GM ones can run as high as $8 per pin which is way too expensive.
Timeslip 08/12/06
AF Community Guidelines
Old 10-30-2010, 07:37 PM
olopezm's Avatar
Ah thanks Bob and grandpirxgtx00 I was afraid to brake the panel itself, I'll take a quick look at it tomorrow since I'll be replacing front brake pads...
I'll make a visual inspection and just in case I'll take some pictures and post them here.
Best regards,
Oscar.
Old 10-30-2010, 09:20 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
i strongly recommend getting a door panel pin removing tool, or at the very least, a screwdriver to pry the panel from the door. if you simply pull the door panel it will crack and or break. whatever you use to pry it off, try to get as close to each pin as possible
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
Radio problems/ Rt rear window won't move/ Lights dim when shifted in Reverse Baxoid Grand Prix 2 01-03-2010 06:50 PM
06 grand prix door lock problem shadetreejr Grand Prix 2 08-04-2008 07:51 PM
97 grand prix power window problem goldsun767 Grand Prix 4 01-03-2008 12:15 PM
Tags
door , panel , window
