Old 10-22-2010, 09:32 PM
pagraham pagraham is offline
2000 Silverado rear suspension issue
I have a 2000 Silverado ext. cab, the rear drivers side is approx. 1.5" lower than the pasenger side, what should I check? could it be a bad shock, thanks
Old 10-22-2010, 09:43 PM
danielsatur danielsatur is offline
Re: 2000 Silverado rear suspension issue
Is there a tool box, or lots of weight on the drivers side?
Old 10-22-2010, 10:10 PM
no, nothing out of the ordinary
Old 10-22-2010, 11:54 PM
What about in the last 10-years?
Are you the orignal owner?
Visual Inspect the Spring + mounting bracket on rear drivers side, and compare with the rear
passenger side.
Old 10-23-2010, 08:34 AM
kahjdh's Avatar
kahjdh kahjdh is offline
You prob have a broken leaf spring. Move common with fords but I've seen them all break. Check to see if all of them line up and are not loose, they usaully break in the middle by the axle.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 10-23-2010, 09:32 AM
j cAT j cAT is offline
the fuel tank and you are on the driver side. this side does have more weight. Is this 2wd ?? If so the front springs sag on all these type vehicles.
with 4wd if the front is adjusted correctly by the torsion bars, then replace the rear springs [both sides] and make sure the shocks are good or replace because bad shocks or over loading will damage the leaf springs.
with aftermarket lift kits , the blocks used will cause this .
2000 Chevy Silverado 4x4 tranny issue nymike Silverado 3 03-05-2010 09:31 PM
2000 Silverado 5.3L 1500 4x4 Silverado_Dude Silverado 21 11-24-2009 11:02 PM
2000 Silverado Rear Questions Mod_12 Silverado 16 05-25-2008 11:49 AM
2000 Silverado rear end problem rjones082002 C/K 3 11-19-2005 11:49 PM
2000 Silverado rear disc brake replacement patssue Yukon 1 10-22-2005 08:25 AM
