Old 11-23-2009, 07:13 PM
Silverado_Dude Silverado_Dude is offline
2000 Silverado 5.3L 1500 4x4
Im not sure what rear-end i have does anyone know how to tell? either by the stats from the title or just some tips on how and where to look to tell?
thanks ahead of time
Old 11-23-2009, 07:59 PM
zaac zaac is offline
Re: 2000 Silverado 5.3L 1500 4x4
I have the same truck and mines a 8.625. This guide should help or you can call GM with your vin # and they can tell you anything about your truck.
http://www.eaton.com/ecm/groups/publ.../ct_128302.pdf
Old 11-23-2009, 08:34 PM
Can i put a 4.10 in there, and what difference would i notice?
Old 11-23-2009, 08:37 PM
Sure but would have to do the front also. I have 4.10, revs 1800 at 60mph. Don't think it would be a huge difference from 3.73 and would be an expensive project.
Old 11-23-2009, 08:44 PM
j cAT j cAT is offline
your vehicle most likely has the locking diff 3.73 gear ratio..inside the glove box the codes are listed which will reveal this..
to put a 4.10 gear set in would reduce gas mileage. you would gain more pulling power though.. good if you drive in mud/plow heavy snow etc...
Old 11-23-2009, 09:07 PM
what codes signify a 3.73 limited slip vs. a locking...or 4.10 limited slip vs. a locking?
Old 11-23-2009, 09:26 PM
Should find them here. G80 is the locking diff.
http://www.marshu.com/images-website...-car-codes.pdf
Old 11-23-2009, 09:53 PM
didnt find the code...all there was, was a sticker saying the camper weight load etc etc
Old 11-23-2009, 10:49 PM
No RPO codes in your glove box? That's weird.
Old 11-23-2009, 11:12 PM
you can see it was there at one time...the outline of the sticker is still there but no sticker
Old 11-24-2009, 07:46 AM
I would do a vin search on this vehicle...could be a problem here..
Old 11-24-2009, 02:59 PM
well it wasnt the differential, i got it serviced this morning and there were not any particles at all. What else could there be to make loud clunking sounds when u shift between reverse/drive...then the other day i was turning and my rear left wheel locked up?
Old 11-24-2009, 03:22 PM
with that info ...did they remove the rear cover ? how do the gear teeth look ? these locking differentials will crack teeth , fall off if when new not properly broken in...
Old 11-24-2009, 03:50 PM
he said he pulled the plug (and that it is magnetic) and there were no shaved metal pieces or any other particles in there, he did not take the cover off
Old 11-24-2009, 05:47 PM
that is how the hacks do it, internally there is a magnet on the cover. also the gear teeth need crack inspection and housing needs cleaning,
this is another reason why these rear dif's fail , hack maintenance.
Tags
1500 , differential , rear-end , silverado
