Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-09-2009, 07:35 PM
floridacamry floridacamry is offline
Oil Pan Gasket- cork gasket or seal packing - or both?
I have a 1995 2.2 Camry and I am getting ready to replace the oil pan gasket. I did this a while back and used a cork gasket at the time, but it has started leaking again. After reading several posts I want to make sure that I understand this correctly- don't use the cork gasket that they sell at the parts store- just use the seal packing material from Toyota? If it is ok to use the cork should I be using the seal packing along with it? If I should not use the cork is it ok to use the Ultra Black RTV from the parts store? Any help would be appreciated. Gary
Old 08-10-2009, 09:27 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Oil Pan Gasket- cork gasket or seal packing - or both?
Cork isn't the best these days, but the key is to not over torque the bolts. I also use the oil-resistant RTV to help hold it in place while reinstalling the pan, and seals the cork surfaces from absorbing any oil.
Install the pan with the gasket that has been coated with sealant on both sides and allow the sealant to fully cure. Then retorque to spec. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-10-2009, 08:52 PM
Thanks for the info- I guess the trick now is to figure out how much sealant to use on each side.
Old 08-11-2009, 07:53 AM
jdmccright's Avatar
The RustBuster
Not very thick...maybe 1mm or so. You don't want to get it too thick or it will squeeze out and possibly fall into the pan over time.
Straighten out the oil pan sealing surface with a small hammer or a fine file and sandpaper. Also make sure the block surface is clean and free of old gasket/sealant, nicks, scratches, dents, and gouges...file and sand smooth them away.
Lay the gasket on some newspaper block side down and smear it on the pan side with a finger until it is fully wetted, then lay it on the pan and repeat for the block side. I usually give it 5 minutes to start curing, but you can assemble it immediately since it usually takes at least a few minutes to wrangle it back into place. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-06-2009, 09:47 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
That may work just fine, but I like to perform all service by the book. (1994 Camry 4 cylinder, 195,000 miles).
FSM (factory service manual) calls for FIPG (form in place gasket material) only for the engine oil pan seal. The automatic transmission pan gets a factory cork gasket with no sealer.
The book is fairly specific about application - gives an illustration and comprehensive directions.
Make sure sealing surfaces are completely clean of oil. I use Berryman B-12 carburetor cleaner as sort of a universal cleaner as it leaves no residue and doesn't harm O2 sensors.
Applied properly FIPG lasts a long time.
Exhaust has to be removed for oil pan removal. You should plan on replacing the gaskets, and for the small additional cost, I also replace the castellated nuts.
Check the FSM drawing for "non reusable parts."
