Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 03-14-2008, 11:43 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Kinda stupid turbo question
Is it possible to lets say install a full turbo kit... all the hardware but say no fuel, and just have it basically not spool? Like having in place, but basically not be "on"? I'm thinking, keeping the wastegate open so there's no boost building and just running straight through like it would normally then right?
Don't ask... I'm thinking.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-14-2008, 01:39 PM
steviek's Avatar
steviek steviek is offline
Re: Kinda stupid turbo question
It is of course possible to like weld the wastegate open. You will lose power though seeing as it becomes a more restrictive exhaust set up.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-14-2008, 01:48 PM
steviek's Avatar
Now that I think about it though even with the wastegate welded open I think the turbo will still build SOME boost on a small turbo like that but likely very very small amounts. Nothing that the motor or fuel system wouldn't be able to deal with.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-14-2008, 01:56 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
so in theory it is like bypassing the turbo?? I would think the turbo might be building boost, then not being able to use it. Not a good idea. Just get a cheap 13g or 14 b if you have to.
Scratch that.
Just wait until you have fuel. There is no sense in having a turbo on there unused especially if you get in an accident and have to replace it all anyway.
Don't act like you don't love it.
503/2000
Old 03-14-2008, 02:00 PM
david-b's Avatar
Dave is THAT guy
I figure it would still do something. There's still coming in/out on the turbine, so it'll be spinning a little.
The reason why I'm asking is because I'd rather do everything piece by peice if I were to do a kit on the car now. So do all the hardware/welding (pipes, IC, turbo...) one day and still have a functioning car. Then do fuel another. Actually I would do the fuel first, but I forget my reasoning behind the question now, but I'm sure it was good.
75 Monte Carlo
Old 03-14-2008, 10:49 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
To answer your question, yes you could install everything and leave the wastegate open and not build any boost. You may build a psi or two at a full throttle run (which you shouldn't do anyways) but normal driving will be fine.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-15-2008, 12:31 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
if its internally gated, just remove the actuator from the flapper... no boost... accept for maybe 1-2psi about redline... (16g)
