Old 10-19-2010, 10:06 AM
adam.kaylor's Avatar
adam.kaylor adam.kaylor is offline
New Ignition
Well, a couple weeks ago I had the unfortunate event of breaking a pen off in my ignition, yes a pen. I was in a drunken stupor and had the bright idea that i could start my car, well it didn't work too well.
I ordered a whole new ignition switch, not just the part that you put the key in.
From the looks of the new ignition, I need to take everything off the steering column just to unbolt the old one. Is this correct, or is there another alternative? And if this is correct, what needs to come off to get to it.
Thank you
Old 10-19-2010, 04:07 PM
Davescort97 Davescort97 is offline
Escort guy
Re: New Ignition
The common mode for replacing the ignition switch is to take the steering wheel off and disconnect the multifunction switch and take it off. There is an easier way. Take the U clamp off the steering column and drop it down. Then, take the three multi-function switch connectors and disconnect them. Remove the screw that connects the multi-function switch to the steering column. Pry up the tab that secures the switch harness retainer to the bracket on either side. Pull the retainers off the brackets. Take the multi-function switch off of the steering column.
Disconnect the ignition switch electrical connector.
Remove the switch mounting screws and take the switch off.
Old 10-19-2010, 04:58 PM
jd-autotech jd-autotech is offline
Re: New Ignition
dont pull the keeper pin until u got the new ignition in or your key will be stuck in the ignition forever
Old 10-19-2010, 11:33 PM
Re: New Ignition
Ok, thanks Dave. I was hoping another way was possible, but they both sound like the same amount of work but, it will be a learning experience.
What is the keeper pin? I already pulled the new keys out of the ignition and it goes back in but, I didn't install it yet.
Old 10-20-2010, 11:25 AM
Escort guy
Re: New Ignition
I think the keeper pin holds the tumblers back in the lock until you get it installed.
New Ignition or new module's? lisaaaalisa39 Vision 0 03-05-2008 12:55 PM
Do I Need A New Ignition? myelevatorbeat Vision 0 10-26-2004 10:32 PM
Install a new Ignition switch '94 Sub. turn_on68 C/K 3 08-30-2004 05:16 PM
new ignition switch 97 sunfire MrGfted General Discussions 1 06-10-2004 05:25 PM
Do I really need new ignition parts? DDMTK421DS Mustang Talk 1 01-14-2004 09:46 AM
