Old 10-15-2010, 08:59 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool CLogged, and I mean CLOGGED....
...Cabin Air filter on a 2008 Kia. I mean a 1/4" inch layer of almost black crud on it with fragments of leaves and some string(!) This car had 23,500 miles on it at the time I took it to valvoline. I did not drive the first 14,000 miles on it, and wonder just where this car had been before I bought it used.
Was this the reason my defroster was never able to keep my own breath off the insides of my car windows? The heater still worked in winter.
Have since been replaced, and windows stay clear unless using "recirculate" position on my Heater in winter. Also no more "oily slime" on windshield which a whole bottle of Windex could not get out previously.
**My last car with cabin air filter, my 1996 Ford Contour, it's filter was just turning light gray at 35,000mi.
Old 10-15-2010, 11:09 PM
danielsatur danielsatur is offline
Re: CLogged, and I mean CLOGGED....
I replaced my cabin filter with nothing, because they mold, and don't hold up to weather.
Old 10-16-2010, 03:37 PM
Cool Re: CLogged, and I mean CLOGGED....
Sorry to hear that. I thought about it for a few minutes and then realized, hey, what if water/moisture is crossing the engine bay/pax cabin threshold by some "unauthorized" means - I.E. a rust hole, missing/mislocated rubber seal, etc? Either that or a drainage route for such moisture has become obstructed, creating a mold environment.
How old is the vehicle?
Old 10-18-2010, 09:36 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Black crud? My first guess would be a smoker had the car before you did. Of course, you'd probably smell it but those sneaky dealers can shampoo the crap outta the carpets and upholstery for very little cost and make it smell like new...for a while.
I will say that the cabin air filters do help keep crud from the outside from getting into the blower, A/C evaporator, and ductwork...cleaning or replacing a filter is alot easier than cleaning those other parts! I would absolutely recommend leaving it in if you also smoke, travel with your pets frequently (hair!), or live in an area with lots of trees (read pollen, leaves, and the occasional acorn!).
If you can get in there with disinfecting wipes or a cloth sprayed with Fantastic or 409 to help clean that gunk out, your air diverter doors will work better...the more you can disassemble and remove to clean, the better! Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Low RPM and O sensor codes? jb777 Grand Cherokee | Grand Cherokee SRT8 4 10-16-2010 03:53 PM
05 TJ cruise control and heating and cooling problem TheRecklessOne Wrangler 1 02-26-2009 10:43 PM
97 3.8L N/A Starts and Stalls Clogged Cat? Fuel Issue? brianr8 Grand Prix 18 01-10-2009 08:47 PM
new project, low and mean baggedon 22's WIP - Street 3 08-26-2006 12:36 PM
tattoo symbols and meanings highteknology COMPLETELY off-topic 31 10-01-2005 03:56 PM
Tags
air , cabin , filter
