Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-15-2010, 08:12 PM
jb777 jb777 is offline
Low RPM and O sensor codes?
Like alot of other people on here I was having problems with my 4.7 JGC the problem was when I got to a stop light my rpms would drop to about 400-450 then my check engine light came on and said my O sensor Bank 1 Sensor 1 up stream was bad I changed it out and the same thing happened check engine light and low r's so I changed the spark plugs, cleared the codes and now it runs better but the check engine light keeps comming on also every once in a while it does not want to start it will turn for a while before it starts, so here are the codes its pulling now, I dont want to keep throwing money away on o sensors if thats not it. Any help would be awesome.
Oxygen Sensor Bank 2 Sensor 2 Voltage High.
Oxygen Sensor Bank 2 Sensor 2 Heater Performance
Oxygen Sensor Bank 1 Sensor 1 Voltage High
Old 10-15-2010, 08:25 PM
danielsatur danielsatur is offline
Re: Low RPM and O sensor codes?
Isn't bank 1 on the drivers side?
Old 10-16-2010, 11:25 AM
Yes, Bank 1 is on the Drivers side, the same side as cylinder #1. That was my first code Drivers side before the converter so that is the one I changed and it did nothing, I reset the codes and it went right back to what it was doing.
Old 10-16-2010, 12:44 PM
Making sure, that we are on the same page, because Ford's bank 1 is on the passenger side.
Is this a H02 sensor 4-wire?
1) Even though the upstream HO2 sensor is new on bank 1 , roll it with bank 2.
2) Visual inspect the 4 wires on bank 1 for heat damage.
3) Check fuse for the H02 sensors.
Also look at similar threads at the bottom of yours.
Old 10-16-2010, 03:53 PM
Yes it is 4 wire, the wires look good there were two fuses a little clear 15amp that said Oxygen Sensor and one black box fuse that said rear oxygen sensor, the 15 amp one was good I dont know how to test the rear one? And what do you mean by roll them swap them with one another?
O2 Sensor and Trans codes...also some interesting behavior after an oil change. beach87 Lumina 0 05-24-2010 04:35 AM
hesitation at low rpm and back fire YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 01-12-2006 12:45 AM
starts up with low rpm and oil light comes on when it hits low rpm,wont rev pass 2000 clough1022 Eclipse Problem Diagnosis 7 08-01-2005 02:49 AM
car wants to die at low rpms, and now i've lost heater fan ryanerik Escort 3 03-01-2005 05:20 PM
Very Low RPM/ and Bogginess-----Please HELP!!!!! summertime_civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 08-04-2004 05:41 AM
