Old 08-03-2004, 08:59 AM
summertime_civic summertime_civic is offline
Very Low RPM/ and Bogginess-----Please HELP!!!!!
Just within the past few weeks my '95 civic (d16z6) has developed a problem idling. Once it has warmed up it only want to idle between 500-600 rpm. Before it has warmed up it seems to idle fine except for the constant bogginess when I try to get things rollin' (which also started at about the same time the idle screwed up. It doesn't seem to pull until it reaches about 2500 rpm. The ecm is not throwing any codes and I've tried adjusting the Idle screw and the throttle cable. Of which the cable has since been loosened to prevent stretching. I just can't seem to figure this one out on my own. Any help or suggestions would be greatly appreciated!!!! Thanks in advance!!!
Old 08-03-2004, 09:50 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Very Low RPM/ and Bogginess-----Please HELP!!!!!
Check the easiest thing - Spark plugs.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 08-03-2004, 02:28 PM
lithod02 lithod02 is offline
Send a message via AIM to lithod02
I am having the same problem also, but I have bogginess up till about 3500-4000 rpm in all gears. then it picks up power. I changed my plugs a few weeks ago, but it is still doing it. I would like to know if what it is too.
http://www.freegizmos.net
Old 08-03-2004, 03:20 PM
Civic Mod
Hrm. When I had boggyness with my car spark plugs fixed it. Did you gap them right?
Maybe check your plug wires or distributor.
Autocross Help Page
Buy my Civic parts!
Old 08-04-2004, 05:41 AM
Wires r next on my list I've already checked and regapped the plugs... and still no change.
