Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-13-2010, 12:24 PM
defender90 defender90 is offline
Heater Fan Stays Running
Hi,
I have a '97 Regal GS.
Even with the car off, key out, the heater blower runs by itself.
I start the car, push the console switch to off, then hear the A/C clutch engage and the blower motor goes to high speed. I push the switch where I can adjust the temp(on basically) and the A/C clutch disengages. While I was under the hood, car off, key out, the fan started, then stopped then started. I pulled the hi blower fuse when I got to work today. Hopefully nothing else too current hungry is going to be running behind the scenes. The car seems possessed. Any ideas? Anyone experience this?
Thanks,
Steve
Old 10-13-2010, 01:29 PM
Re: Heater Fan Stays Running
Sorry, I didn't read past post to this same problem. It looks like A bad blower control module, correct? Can someone tell me how to access this module. Is it under the dash? Can it be accessed through a removed glove box?
Thanks,
Steve
Old 10-14-2010, 06:10 PM
big white bufflo big white bufflo is offline
im not sure on the regals but i have a lasaber did the same thing your on the right track look for the blower moter and the wires that is were the control mod is my lasaber is under the hood
Old 10-16-2010, 11:23 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Since this is GS do you have the digital climate control? You have a bad blower motor control module or blower motor resistor if manual HVAC. Remove the blower and towards back firewall you will see it.
Timeslip 08/12/06
AF Community Guidelines
Old 10-16-2010, 12:03 PM
Scrapper Scrapper is offline
AF Premium User
i put a module on a 91 buick park avenue and it was under hood on top under firewall where all the big fuses are and theres a cover over the fuses.
Old 10-16-2010, 12:28 PM
BNaylor's Avatar
Please keep posts relevant and on-topic to the particular year and model GM car. This is a GM Buick Regal "W" body" forum.
The blower motor control module on a '97 Regal GS is located in the cabin under the dash after the blower motor is removed and not under the hood like the GM "H" body cars.
Timeslip 08/12/06
Heater fan stays on now! dtb78d Thunderbird 1 07-07-2008 07:28 PM
heater blower stays running with motor off skyjack Grand Prix 12 02-08-2008 12:04 PM
signal flasher location 95 monte , and heater fan only runs on high 2000 monte SS wayne56 Monte Carlo 7 12-13-2005 06:38 PM
91 4Runner - heater fan stays on jimdixie 4Runner/GX470 2 06-02-2004 03:40 PM
2001 Caravan a/c, heater fan only runs on high cagey Caravan | Voyager 3 01-20-2004 09:09 AM
