Old 01-09-2004, 07:15 PM
cagey cagey is offline
Arrow 2001 Caravan a/c, heater fan only runs on high
I have a 2001 Caravan Sport that the a/c & Heater fan only runs on high speed. This is the same for the panel controls and the back seat controls as well. Since its getting some power I'm guessing its not the fuses. Not being much of a car guy I could use some suggestions. Thanks in advance!!!
Old 01-13-2004, 07:38 PM
hossierrun hossierrun is offline
This is usually an indication of a bad resistor block. For all speeds, except high, the switch diverts the power return lead (to ground), through the resistor block. On high, the return lead is directly connected to ground. I don't know where the resistor block is on a vehicle that new, but someone with a service manual should know.
Old 01-13-2004, 10:16 PM
Ghostman Ghostman is offline
The resistor block is under the wiper module on firewall, passenger side, you may or may not have to remove the wiper module to get at the resistor.
Old 01-20-2004, 09:09 AM
dodgerunner dodgerunner is offline
Send a message via AIM to dodgerunner Send a message via Yahoo to dodgerunner
You want to be careful if you are replacing the resistor pack.
Sometimes the reason that the pack goes out is that the fan motor is drawing to much current. (due to going bad.)
If this is the case and you replace the pack, it could burn out again within a very short time.
Only way to know for sure is to check the current the motor draws and see if it is within specs for the motor. Sorry I don't know what it might be though....
DR
2001 dodge caravan sport front heater fan on high only shaws5 Caravan | Voyager 4 01-30-2007 04:45 PM
signal flasher location 95 monte , and heater fan only runs on high 2000 monte SS wayne56 Monte Carlo 7 12-13-2005 06:38 PM
heater fan only working on high rjreds Durango 4 10-04-2005 06:28 PM
heater fan only works on high charliewensman Contour 4 08-20-2005 06:02 PM
AC/Heater Fan Only Works on High mjcbmw 5 Series 1 07-18-2005 09:09 AM
