Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 10-04-2010, 07:13 PM
dancam dancam is offline
03 envoy cv joint leaking
i got a 2003 gmc envoy SLT my driverside front cv joint looks like it is leaking is there a seal bettween the cv joint and the transfer case or do i have to just replace the cv joint and if so how hard would it be to replace both or just the seal or just the cv joint
Old 10-04-2010, 07:37 PM
maxwedge maxwedge is offline
A990 racer
Re: 03 envoy cv joint leaking
If it is leaking transfer case fluid than it is the seal in the case.
Old 10-04-2010, 07:43 PM
if i contunie to drive will the the wheel fall off or seize up on me
or will it cause any other damage to the case or cv joint
Old 10-05-2010, 08:22 AM
A990 racer
Only issue is keeping the ft diff case full.
Old 10-05-2010, 10:18 AM
Thanks for all your help that was helpful
Old 10-07-2010, 02:00 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Just to correct the terminology:
The front CV shafts connect the wheels to the front differential, not the transfer case. The transfer case accepts the output shaft from the transmission and splits it to the forward and rear differentials.
It sounds as if you are leaking lube oil from the front differential. I am clarifying this in case you ask someone to check the fluid level of the wrong component by accident.
You can just replace the seal from the CV joint to the front diff, though a number of pieces have to come off first. Not topping the fluid level off will eventually let the front diff go dry, causing wear, overheating, and eventual failure. Depending on how much you are losing, I'd suggest having it replaced soon...it's easy to forget about.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-07-2010, 06:59 PM
A990 racer
Red face Re: 03 envoy cv joint leaking
Hmm, fill the t/c huh!!, boy I must have been tired from working on the 51 Chevy p/u truck in my shop, good correction.
CV joint leaking and front end noise sparky65 Montana/Montana SV6 8 10-09-2009 07:49 PM
envoy 2005 rear a/c not working front a/c only throws cold air that can't be regulate MakeupBoricua Envoy 3 07-11-2009 02:55 PM
Envoy Fan WesPomp Envoy 3 03-31-2009 03:28 PM
U-Joint Leaking? bigcoconut C/K 10 09-02-2008 08:37 PM
1998 Drivers side outer CV joint leaking steamplant Villager 1 09-26-2007 11:26 PM
