Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-10-2009, 04:48 PM
MakeupBoricua MakeupBoricua is offline
Unhappy envoy 2005 rear a/c not working front a/c only throws cold air that can't be regulate
hola
I have a 2005 Envoy..since I bought it new the vehicle presented problems with the rear a/c not working and when this happens the front a/c (manual) blows cold air only (it can not be regulated) also the damper for recircling does not activate. The first like 8 times they would change fuses,also the blower assembly was changed. The last thing done in march 2007 was replace the block assembly,wiring harness junction engine. This worked until now. What fuse should I look for, and how doI know if this fuse box is ok?
Old 07-10-2009, 06:49 PM
maxwedge maxwedge is offline
A990 racer
Re: envoy 2005 rear a/c not working front a/c only throws cold air that can't be regu
The fuses are under the rear seat, look in the owners manual for the proper fuse and it is indicated on the cover for the fuse box.
Old 07-10-2009, 09:46 PM
I have checked those and are good, I thought there were more a/c fuses in the other fuse box under the hood
Old 07-11-2009, 02:55 PM
A990 racer
If there are they are indicated on the cover, no?
Tags
2005 , a/c , envoy , front , rear
