Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-30-2010, 11:28 AM
2000bonny 2000bonny is offline
Slow cranking 2000 Bonny
I have a 2000 bonneville with 140k. Just a couple days ago, the engine would not crank over like normal. It almost does not crank at all. I checked the alternator output and see 14.6v. The battery, and the leads to the fuse panel are all reading 12.4v. I do not believe it is the battery for those reasons. Does anyone have any suggestions?
Old 09-30-2010, 12:24 PM
Re: Slow cranking 2000 Bonny
I disconnected the negative cable, and using my Fluke set at 10amp, I found there was a reading of .76. Does this mean the battery is bad, or is something else draining it?
Old 09-30-2010, 02:22 PM
danielsatur danielsatur is offline
How old is the battery?
If > 4-years, replace battery.
If < 4-years, have the battery charged & load tested.
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 06:25 PM
2000 bonnie won't crank, voltage loss, No Codes! joeharley Bonneville 7 03-19-2008 01:20 PM
slow cranking, sometimes? joe92k1500 C/K 5 08-21-2004 10:33 PM
94 XJ VERY slow cranking 94XJ Cherokee 1 07-22-2004 07:03 PM
99 Caravan - slow cranking - starter? mhavens Caravan | Voyager 2 10-29-2003 08:47 PM
