Old 05-11-2003, 11:03 PM
xlosinghopex xlosinghopex is offline
Send a message via AIM to xlosinghopex
Cat removal
I remember seeing a post a little while ago about removing the cat and just putting it back on when you get your emissions tested. I like this idea and now that its warm out I'd like to do it. I'm not sure how this works though. People who did it said they used a straight pipe, can someone explain this? Do I have to buy something specific to do this? Also is this gonna screw with my O2 sensor and flash the check engine light? Can someone just clarify this procedure so I know what to do? Thanks in advance.
Old 05-12-2003, 12:30 AM
SiRII's Avatar
SiRII SiRII is offline
depending on what car you have. you can bolt on a test pipe very easily. some test pipes have 1-2 inserts for your o2 sensor. if you have a header that doesn't have the o2 sensor insert on it. then you'll have to buy an extension and connect it to the test pipe. but most headers have it.
Old 05-12-2003, 12:07 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
SIRII, i dont know what info you are reading but you gotta stop with all this.
on your del sol there is one O2 sensor before the cat on your exhuast manifold, if you remove your cat and put a test pipe in, basically a straight piece of piping, your car will be louder for one, and prolly start to have an odor from it. but make sure you put the cat back on before you get inspected, or else you will fail.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-12-2003, 02:26 PM
SiRII's Avatar
why do you think i said most headers have the o2 sensor on it.
Old 05-12-2003, 05:31 PM
OK, so how can I get one of these test pipes? Also what kind of gains can I expect? And is there anything bad that could happen?
Old 05-12-2003, 06:03 PM
b16a3sol b16a3sol is offline
just go to an exhaust place and ask for a piece of piping with a flange welded to it so it can be attached. the other way to do it is to just take out the cat from its housing.
the bad things that could happen are a cop finds out you dont have a cat and tickets you, which can be a sizeable $200 ticket. you could forget to put it back in and fail emissions as well as get a ticket. it will be louder, as well as smell differently because the toxic gasses arent being converted to something else. you will also be polluting a lot more, but you dont seem to mind that.
the gains will not be that spectacular, about the same as a header. if it were me i would just skip this mod and either invest in a hi-flow cat or focus on making the motor stronger in other areas.
and SIRII, i have to agree with crxlvr, you seem to have somethings backwards in what you are reading.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 05-12-2003, 06:13 PM
SiRII's Avatar
how do you figure?
Old 05-13-2003, 04:34 PM
crxlvr's Avatar
first off sir, every header or manifold has an O2 sensor, so wow for you if you knew that.
id suggest just getting a high flow cat, such as the catco model, i have it and i noticed a gain with it, plus i cant be ticketed and it doesnt smell since there is no cat there.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-13-2003, 04:56 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Not every header has an o2 sensor bung. But yeah I suggest using a high flow cat instead.
Old 05-13-2003, 05:10 PM
crxlvr's Avatar
they are supposed to tho, just cuz a company is worthless doesnt mean they shouldnt be there.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-13-2003, 05:30 PM
SiRII's Avatar
i've never got ticketed for having the test pipe
Old 05-14-2003, 10:33 PM
JDM00CivicEX JDM00CivicEX is offline
goto www.racingpipes.com they have different test pipes for different cars.
Old 05-15-2003, 12:54 AM
SiRII's Avatar
There's some nut here in Az with a black 88-91 hatch with a swap and i think he's either running strait header or a b-pipe, and that SOB is loud. At the illegals, i was standing right next to the car when he spanked this Firebird Trans Am. My hearing was messed up for 3-5 days.
Old 05-15-2003, 09:24 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
www.testpipe.com also has a large selection of test pipes, they even got ones with a place to put your O2 sensor
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 05-16-2003, 12:53 AM
where at in AZ? if you are talking about in tucson, the last time i was there it sucked ass. there were barely any good cars and hazardous seemed to be trying to take control of it. maybe you were lucky enough to see the supra owned by ryan woon with the biggest turbo he could fit into that engine bay hooked up. last i heard he ended up breaking 1000hp on his stock bottom end for around 1000mi before it blew up.
as for the straight pipe on that hatch, its not worth going deaf for an extra horsepower, especially when you are doing something illegal. dumping straight into the atmosphere will most likely rob power than give it, considering most engines like to utilize scavenging to get rid of excess exhaust still stuck in the cylinder.
cat. removal question camodiak Grand Cherokee | Grand Cherokee SRT8 2 08-07-2004 07:43 PM
Cutout and cat-removal behvah78 Grand Prix 9 04-18-2004 11:47 PM
cat removal aussier33 General Discussion 0 08-21-2003 04:00 AM
cat removal rkturbo 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 9 03-09-2003 12:05 PM
Cat removal raptor Performance 7 11-19-2001 01:56 PM
