Old 05-05-2003, 05:30 PM
Colov99's Avatar
Colov99 Colov99 is offline
Send a message via AIM to Colov99
Angry arrgggg(paint tips anyone?)
ok so im trying to paint my 350z tamia gold (ts-19 i think (bottels downstaisrs)). so the first time i do it i just spray on with out primer. some orange peel so i try to compound it using automotive compound... paint comes off... so i finish taking the paint off with these chem pads (they dont hurt plastic but they are solvents). then i primed it with testors flat white. major orange peel, so i sand it down till its all smooth. next i spray on the gold paint. minor orange peel. (half the can or more used), so i go to sand it with 1200 grit wet and the paint comes off... argggg. any sugjestions on my 3rd repainting?
thx.
2007 M6S SVE Onyx Black "TAMA"
MS CAI, Audiolink IPOD
Old 05-05-2003, 05:34 PM
freakray freakray is offline
AF Modelrater
A ton of help waiting to be discovered.....right....
HERE
AF User Guidelines
Old 05-05-2003, 05:38 PM
Colov99's Avatar
ive actualy read it.. .im not that much of a noobi i just dont post much. i just wanted to knwo if i had totaly screwed something up .. or if this is just bad luck for me.
Old 05-05-2003, 05:57 PM
AF Modelrater
If you're getting orange peel the whole time, you're spraying from too far away which is causing the paint to dry too much whilst airbourne and so it does not smooth on the surface of the model.
AF User Guidelines
Old 05-05-2003, 05:58 PM
daggerlee's Avatar
Sounds like you aren't spraying enough coats and you sand through to the primer too quickly?
I would advise to use a higher grit paper and to use lighter and fewer strokes. At least 2000+, and be wary of sharp or raised edges, these places are where the paint is thinnest.
Dan
Old 05-05-2003, 06:08 PM
Deniz Deniz is offline
Did yuo wash the body in warm water with a mild detergent? Greasy spots can cause alot of problems.
Old 05-05-2003, 06:10 PM
Colov99's Avatar
theres still primer on the car the gold just came off realy easily. and even though the gold was sanded off ther was still orange peel. guess ill go try to find some c2c and a diffent type of primer and try adding more coats of paint this time
Old 05-05-2003, 06:12 PM
Colov99's Avatar
i washed the car in dishsoap before i sprayed the primer and i sanded it in warm water . i guess not enough paint got on the model. time to strip again...
Old 05-05-2003, 06:15 PM
daggerlee's Avatar
Also, Tamiya spray paints are incompatible with Model Master primers, since MM primers are enamel based and Tamiya is lacquer based (remember, LEA - Lacquers first, enamels second, acrylics third - not the other way around!)
Also, metallic colors like gold need to be clearcoated in order to be polishable...and you need to let them cure for a period of time before you can do any sort of polishing work
HTH
Dan
Old 05-05-2003, 06:23 PM
Colov99's Avatar
so should i have cleared before i tried sanding out the orange peel? i wana get it right this time i cant afford to keep buying the same paint . and the store doesnt sell tamiya primer so whats a good substitute? tahnks
Old 05-05-2003, 06:31 PM
primera man's Avatar
"P-Man"
Strip the model right back and start again.
2-3 light coats of primer followed by 3-4 finish coats 10-14 days later.
dONT mix the brands of paint...stick to the same type like tamiya primer and finish.
View All My Models Here.
Old 05-05-2003, 06:41 PM
Colov99's Avatar
will a tamiya white work as a primer? and for polishing will automotive compound work? (the store i go to doesnt sell any finishing supplies) other then that any other sugjestions?
thanks
Old 05-05-2003, 06:56 PM
daggerlee's Avatar
Try to get some Duplicolor, Plastikote, or KRylon primer at your local Walmart or home improvement store
If you can't do that Tamiya matt white would work, and yes automotive compounds should work.
Dan
Old 05-05-2003, 07:00 PM
Colov99's Avatar
thanks ill look fro the krylon primer at the hardware store. thanks for al lthe help
-c
Old 05-05-2003, 11:08 PM
CYPH3R CYPH3R is offline
since u guys here r talking about painting........
how far should i be from my model when spraying?
thanks....
Fuel Economy Tips for a Jeep Wrangler 2009? wranglewithmyjeep Cars in General 0 01-13-2011 08:13 PM
Decal Tips Anyone??? genX Car Modeling 18 02-23-2010 08:30 AM
Any performance tips anyone can provide? Izzy_hot Swift 0 03-29-2007 03:18 PM
Tip anyone? On spraying tyre(tire) lettering Hiroboy Car Modeling 14 01-17-2005 06:46 AM
Anyone got any sick tips? SkYLiNeFrEaK COMPLETELY off-topic 13 01-28-2002 08:55 PM
