Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-05-2003, 02:35 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Power window help please
my passenger power window stopped working... the switch does nothing now. i took allllll of the fuses out from the kick panel and none of them are burned out so i know thats not the problem. are there fuses in the door panel that can get burned out.. if its not a fuse its probably the motor that moves the window up/down.. how do i find out if the motor is broken or not?
Old 05-06-2003, 06:46 PM
PilotMojo's Avatar
PilotMojo PilotMojo is offline
All you have to do is take out the switch assembly,
(the sunroof switch pops out of the instrument cluster; the window switch is more tricky - you have to disassemble the door panel. Use a service manual like Chilton's to find out how.)
and find your way underneath the push buttons.
You'll see 4 metal contacts embedded into the switch, and 2 metal strips which are likely to fall out, be careful with these.
Clean off all that black stuff that has accumulated from all metal areas and replace them.
If you notice that the embedded contacts have quite a bit of wear on them (have large indents in the metal) the switch is likely to be unusable soon. You can try using solder on them, but I'm not too good with that yet.
Your switches should be working fine now.
(thanks NFULFX)
Thats if the power isnt working..... or only works when you press reeeeeaaal hard
1993 Teg GS Automatic (sux)
Old 05-07-2003, 12:25 AM
90gs's Avatar
window doesnt move from either the switch on the driver side or the passenger side.. i dont think they would both stop working at the same time, i think something else is causing it to not work
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
Rear Power Window, Help Please. foxlady99 Grand Prix 2 02-10-2010 09:10 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
POWER Window help please Dmartin_1 Town Car 12 05-08-2007 07:11 PM
Dash lights and power windows help please wwdragon Lumina 0 01-17-2004 08:04 PM
